Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 25th July 2012, 10:24 PM   #11
KatieandDad's Avatar
Default Just an example
The nature of the heatsink is that it will not be very good at dissipating point loads due to the thin fins and the even thickness of the base.
You will need to help it along by spreading the heat sources across the heatsink.
If you calculate the actual area of each fin with all the fins it will be better than 0.5 Deg C/Watt. However, as the fins are very thin at their bases the heat will not travel up the fins very well.
The ideal Heatsink should have thick roots and thinner tips.
Old 26th July 2012, 02:35 PM   #12
NSP is offline NSP  Finland
Yes I noticed that directly when I got them that the thickness of the fins are even and I thought that doesn't matter, but now when you are saying it makes perfect sense that they are not optional.
Well I think I'll go on and give them a try. If they overheat then I know not to use sinks like these. Who lives shall see.
Old 26th July 2012, 02:57 PM   #13
Ah, they look like they where designed for forced airflow.
so mount them close together and but a fan below and be happy!
Michael
Old 26th July 2012, 05:05 PM   #14
Yeah I think so too. Hmm, I don't think fans would be a option for me because the heat sinks will be visible from the outside of the chassis. Would be kinda odd looking. :P
Old 26th July 2012, 05:43 PM   #15
On the outside yes, but not if you mount them on the inside...
Heat Sinks Coulomb Swap Meet 60 28th August 2012 10:51 PM
Heat Sinks Peter Menting Swap Meet 0 16th January 2012 05:09 PM
No heat sinks! lanchile Solid State 7 5th December 2011 11:46 PM
Heat Sinks 95Honda Swap Meet 14 7th October 2005 06:07 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
