Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
A question about locking TRS jacks
Old 26th July 2012, 05:39 AM   #11
qusp is offline qusp  Australia
qusp's Avatar
I dont use either, though I have some of the neutriks here. I'm balanced all the way baby. I use lemo 4 pin OB series, which are truly locking and smaller than most minis. they also circumvent the issue you mention, which was another one of the reasons I decided to change. the fact the phono system shorts the amp and headphones on the way in and out is a deal breaker on its own.
being DIYers, I see no reason to use phono or mini even for single ended systems.
but none of that helps the OP I guess, just an option to consider.
Old 26th July 2012, 10:04 AM   #12
Enzo is offline Enzo  United States
The reason to use standard connectors is compatibility. If you never intend to use anything outside of the immedisate system, use anything. But it might be frustrating to take your favorite headphones to the studio and then try to plug them in with an odd connector on the cord.
Old 26th July 2012, 10:17 AM   #13
qusp's Avatar
i'm aware of that but the standard connectors are ALL **** including 2 x 3 pin XLR, that was a stupid idea for headphones. Its easy enough to make an adapter. using a 4 pin connector you can adapt to anything, use balanced headphone outputs or SE, spades etc whatever. I have adapters for all the common formats but I use lemo directly at home. most do not have to go into the studio and if they do, an adapter should not be a roadblock
A question about locking TRS jacksHide this!Advertise here!
3 TRS in, 3 TRS out, 1 knob volume. pocketdrummer Analog Line Level 3 7th October 2012 02:20 AM
Newbie 3.5mm TRS Voltage Question ramjet69 Headphone Systems 3 2nd January 2012 09:54 PM
1/4" Jacks TS/TRS Panel Mount Jack GLS Audio Headfi Fanatic Group Buys 0 14th July 2010 07:16 PM
output jacks question soundphreak Everything Else 2 9th January 2008 04:47 PM
Question about using RCA jacks. G Tubes / Valves 28 1st December 2004 10:36 AM
Copyright ©1999-2017 diyAudio
