Can polystyrene caps replace my mylar and mica? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st July 2012, 08:48 AM   #1
pshdk is offline pshdk  Denmark
Default Can polystyrene caps replace my mylar and mica?
Hi. I'm real new to this and learning.
I'm doing a recap on a sony N80es amp and was wondering if I can replace the mylar and mica caps in the audio path with polystyrene?
I have read the dielectric sandwich is rolled together with the polystyrene, but this adds inductance limiting their frequency response to a few hundred kHz.
Would this have any negative influence on the sound of the amp? or could it influence the sound of the speakers?
I would just like to use one of the best types now that i'm doing the job anyway. Teflon is a bit to expesive I think.
Thanks,
Paul
Old 21st July 2012, 10:33 AM   #2
SY's Avatar
A good quality PS cap will not be any more inductive than any other type. The disadvantages of PS are temperature sensitivity (heat will kill them faster than polypropylene, mica, ceramic NP0, or polyester) and size per microfarad.
The size issue often causes more problems than it "cures" in amateur modifications. Part placement, layout, and lead length are critical to performance, generally more critical than dielectric (audiophile hype aside).
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 21st July 2012, 10:41 AM   #3
Flux removers may ruin them too. They're a little too 'dainty' for most gear.
Old 21st July 2012, 10:52 AM   #4
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
How so ?
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 21st July 2012, 12:04 PM   #5
"How So?"
By dissolving the polystyrene. Trichloroethane flux cleaners of old certainly used to do that (as I vividly recall - once bitten, twice shy with that stuff) - dunno about the modern eco-friendly products available nowadays.
A
Old 21st July 2012, 12:09 PM   #6
john curl's Avatar
I would recommend metalized polypropylene as the best compromise for many substitutions. The REAL problem caps are CERAMIC that are NOT NPO. Normally NPO caps are small value.
Mica isn't too bad. Perhaps not worth replacing.
"Condemnation without Examination is Prejudice"
Silver Mica caps VS Polystyrene caps KevinLee Parts 41 11th November 2015 03:38 PM
FS: Rifa Polystyrene & some Silver-Mica Capacitors tubemike Swap Meet 0 20th December 2005 05:02 PM
silver mica or polystyrene janey Pass Labs 11 7th February 2003 12:45 AM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 02:02 PM
Copyright ©1999-2017 diyAudio
