Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Noble,Alps,TKD ?
Noble,Alps,TKD ?
Old 29th September 2012, 11:57 AM   #31
dry joint is offline dry joint  United Kingdom
Alps Blue Velvet to cheap attenuators, but I've had a variety of pots made from different materials and various brands and none are close to either of the Chinese stepped attenuators I've had - big one with dale resistors and really cheap surface mounted parts one, the cheap one was best. Comparing expensive pots with attenuators is like trying to find a really expensive candle that is better than an electric light. I wouldn't worry about noises when changing volume, what the sound is like when set and listening that matters.
You might want to look at removing input capacitors on the amp if the source(s) have DC blocking on their output(s), no point in putting the signal through two sets of caps.
21 clicks is not a significant problem and worth the trade off for clearer sound, attenuators simply provide a cleaner signal.
In my experience input and feedback resistors are disproportionately significant, most deisgns have an input resistor or two in either a filter or to make the amp easier to drive. Do you have a circuit diagram or know what the design is?
Old 29th September 2012, 12:18 PM   #32
AudioLapDance is offline AudioLapDance  Canada
Originally Posted by dry joint View Post
One of these will be better than any pot
DACT Type 21 Stepped Attenuator Potentiometer 50K 300B | eBay
or
New 21 Step Attenuator Potentiometer 10K Log Stereo | eBay
They are the same size as regular pots.
Keep in mind those are NOT ladder attenuators but series attenuators. So you have 21 SM resistors in series ...
I have a few and they are a great value.
Jeff
Old 29th September 2012, 12:28 PM   #33
zibra is offline zibra
Its single stage opamp with feedback resistor but I dont really know details that much.
Heres review of that headamp. Simple and fantastic:
High Fidelity
Im afraid its only in polish language though.
Old 29th September 2012, 01:18 PM   #34
Not sure what I have, it was from ebay a few months ago, cost 10 inc del and sounded great compared with pots and a bit better than ladder attenuator with dale resistors. I never thought smt resistors would make much of a difference, live and learn.
The quality of that feedback resistor will matter.
Old 3rd October 2012, 04:45 PM   #35
OK guys I still hgavent bought anything yet as I have some doubts.
What can you say about Goldpoint stepped attenuator then and comparision to "ordinary" Noble or TKD pots?:
Compare Attenuator Types
Im even more interested in comparing Goldpoint to attenuator from ebay. Exactly this model. Anyone tried? im very curious if build quality of such attenuator is worth money over Noble and TKD and ofc to Goldpoint? Also whats SQ?
10K 24 step Attenuator Potentiometer 0.5% Takman REX25 | eBay
Im interested in that model with Takmans, not other with Dale as there is also different build quality I think.
Old 3rd October 2012, 09:50 PM   #36
You'd want the metal film Takman REY ones not carbon REX, individually the resistors cost the same retail so the seller might be able to do one.
Old 6th November 2013, 11:10 PM   #37
impuls is offline impuls  Yugoslavia
Does anyone compare sound of the old black alps rk40 with other potentiometers? And RK27 in shunt connection in comparison with TKD 2508 classic connected?
Old 7th November 2013, 02:00 AM   #38
Bare is offline Bare  Canada
Yikes! 4 pages of drivel postings re the relative merits of various Pots, many of which are Cheap Crap Clones out of China... unbekmownst to their Fanboys :-)
Yet no one gave much notice to the early AKSA post which correctly suggested Gold point Stepped Attenuators.
Then it devolves into Brands of Resistors.
IF you can hear differences betwixt decent quality resistors and the Moron priced ones ..
then you are a true Human Genetic Mutation.. likely deserving to be put on display.
Shamefully many are focused on talking over the next guy, rather than posting information of use.
Gotta love: Open Mouth Forums.
Old 7th November 2013, 03:42 AM   #39
john dozier is offline john dozier  United States
john dozier's Avatar
Early on, I suggested TKD stepped attenuators. Apparently no one was listening or they all had sticker shock. Sometimes, you DO get what you pay for, but only if the rest of your system is transparent enough to reveal the difference. Regards especially to AKSA.
Evil looms. Cowboy up. Kill it. Get Paid.
Old 7th November 2013, 07:16 AM   #40
I want to buy tkd 2508 20k but do not know where. As a easier available solution i try to find a variant where would be and other pot give a similar sound result.
And yes, difference in potentiometers are heard and in an inexpensive systems, does not have to be expensive.
Noble,Alps,TKD ?Hide this!Advertise here!
FS ALPS , NOBLE jazzy Swap Meet 3 30th June 2011 05:15 PM
alps or noble? lanchile07 Chip Amps 8 21st October 2007 03:28 AM
Which pot? Noble or Alps? Or another? deiksac Parts 1 12th May 2007 04:47 AM
sell alps pots & noble sma Swap Meet 0 11th April 2005 11:30 AM
Alps pots vs. TKD pots? TKD worth the extra$$? G Tubes / Valves 11 17th August 2004 04:33 AM
