Help finding Push Tab Terminal blocks? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th July 2012, 11:20 AM   #1
Zero Cool's Avatar
Default Help finding Push Tab Terminal blocks?
I am trying to find some PCB mount Terminal blocks that have push tabs but not having much luck. I have tried the usual sources here in the USA, Digikey, Jameco, Parts express etc etc. What i can find here is the standard screw type terminal blocks that have push tab's on them but that's not what I'm looking for. I can also find single PCB solder type push tabs. But I am looking for a block that has push tabs on the top and PCB pins on the bottom that has isolation between the tabs. I have a feeling this is a European type block and I probably won't find what im looking for in the USA.
Something sort of like these.
It's not about what you can BUY...It's about what you can BUILD!
Old 16th July 2012, 11:54 AM   #2
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Dave,
=> 10-POSITION TERMINAL STRIP W/ QC TERMS, PC MT | AllElectronics.com
Most companies who manufacture these types now are European, e.g. => http://www.hylec-apl.com/Products/El...8/Default.aspx
Here's one in the US : Eagle Connector Corporation - Faston Terminal Block
You can find NOS ones by Phoenix on the bay, keyword is Faston.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 16th July 2012, 12:00 PM   #3
Zero Cool's Avatar
Thanks, those are the best options I have seen yet! I like the Eagle style best so far.
Old 16th July 2012, 01:19 PM   #4
Keystone Electronics has a large selection. E
Old 17th July 2012, 12:04 PM   #5
Zero Cool's Avatar
Ok I found them..sort of...WECO is the brand and there website SHOWS the blocks but they no longer have them listed. so this is definitively the brand. they have some other options that will work too!
Bottom of the page
:: Weco - Products ::
Old 17th July 2012, 02:28 PM   #6
In that case : 900-SUN-5/04 - WECO - 900SUN504 - datasheet
Future USA has the 10-pole 5mm pitch in stock (says that other pitch types are in transit from India)
(the older Weco 900 S+W series was modular, 10-25 pole strips, but could be individually separated. Don't know if that's the case with the current versions)
Rockford P4004 Terminal blocks brandes.cm Car Audio 6 15th November 2009 04:35 AM
Looking for terminal blocks for RF amp 17DoubleE Car Audio 3 30th October 2009 12:05 AM
Where to find Terminal Blocks? spooney Car Audio 4 6th November 2007 08:45 PM
terminal blocks cowanrg Parts 5 12th August 2003 11:32 PM
Using terminal blocks as Speaker connectors? Beggar Parts 4 27th July 2003 08:08 PM
Copyright ©1999-2017 diyAudio
