Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Relay or switch mains
Old 18th July 2012, 09:52 PM   #31
magnetman is offline magnetman  Australia
Genius!
rotating switch 240v 6A min, any ideas?
I have never used a rotating switch before.
I found Shallco switches they seem heavy gauge, check this Series 16 Rotary Switch, 10 Ampere, Single-Hole Mount on Shallco, Inc.
Is this the sort of thing that will be able to switch Neutral and Active simultaneously?
Cheers
Old 20th July 2012, 09:40 PM   #32
indianajo is offline indianajo  United States
indianajo's Avatar
Specs read okay. A 2 section one 16A1-b-2 would be required to switch both hot lines you have in Aust. I don't believe you have a neutral in aust., just a safety ground and 2 hots.
This is a US origin switch. You should be able to find a 2 or 3 pole industrial disconnect at an electrical supply. Ask for a "lockout switch". The hole will be harder to machine, but it is not as likely to rotate in the hole as this device could. I have a lot of lockout switches on SS panels in dead motor drives I fished out of the trash at work. The motor drive is plastic trash, but the SS box and switch and heat sink are nice. Nose around a bar near a food plant, you may meet a maintenance man that can scan bins for you.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 20th July 2012, 10:18 PM   #33
Thanks for the reply indianajo, I have since found a really great switch thats DPNO, see this link if your interested, www.lorlin.co.uk/PDF/RMS.pdf It still present s the problem of becoming loose and rotating but can be tightened with spring washers and maybe nylon blocks either side if it still a problem.
Just as a side note AC in Aus. does have a Neutral, Active and Earth.
cheers
Old 21st July 2012, 08:50 AM   #34
marce is offline marce  United Kingdom
Its got a locating lug to stop it spinning. 2 holes one 6.5mm and one 3.2mm 9.5mm centres and it wont rotate.
Old 21st July 2012, 09:03 AM   #35
It does too. I didn't notice that.
Cheers
Relay or switch mainsHide this!Advertise here!
Mains relay help please :D 6L6 Power Supplies 9 31st May 2012 04:02 PM
Mains Relay blowing Fuse on GC k3ys3r_soz3 Chip Amps 2 6th March 2007 05:25 PM
cap across mains switch? klitgt Power Supplies 4 11th December 2006 08:27 PM
Never try to switch 450V DC at 3A with a conventional mains switch... Eva Power Supplies 28 1st November 2006 09:24 AM
Mains Switch Problems Angel-Baby Solid State 4 23rd March 2004 06:42 PM
