Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Relay or switch mains
Old 16th July 2012, 11:34 AM   #11
magnetman is offline magnetman  Australia
Thanks for all the feedback there is still a lot to consider. It seems that maybe noise is not going to be a issue if I lay out properly. If I do run ac to the front panel it will pass one of the large smoothing caps most likely quite closely. Perhaps shielding is an option.
Cheers
Old 16th July 2012, 03:12 PM   #12
indianajo is offline indianajo  United States
indianajo's Avatar
Peavey triggers the triac with mains AC limited by a resistor and diode through a low cost switch. You only get the hard edge from a triac when it turns on, a triac turn off at ~ two volts AC. So the Power up silence circuit (a J174 jfet with an RC delay) cuts any noise at turn on until the DC power supplies are at full voltage. A relay or hard contact switch can also produce a large sharp voltage edge at turn off.
The triac is in the AC part of the amp, away from the preamp boards. There is a steel divider in the case like a PAS2 preamp between AC and sound.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 17th July 2012, 05:37 AM   #13
gmphadte is offline gmphadte  India
...and diode through a low cost switch...
I suspect it me be a diac.
Gajanan Phadte
Old 17th July 2012, 12:42 PM   #14
marce is offline marce  United Kingdom
A simple relay would do, why use a noisy traic!
Old 17th July 2012, 01:29 PM   #15
Mooly's Avatar
Even Nelson Pass used a triac in the A752 PSU.
Old 17th July 2012, 02:07 PM   #16
lcsaszar is offline lcsaszar  Hungary
Using a SSR (Solid-State Relay) is an elegant solution, but it needs an external control current for the internal LED. I turn on my power amplifier from my preamplifier this way.
Old 17th July 2012, 02:57 PM   #17
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by Mooly View Post
Even Nelson Pass used a triac in the A75 PSU.
Please add that Papa included a snubber across the triac, plus C1/C3, to help suppress/shorten the transients.
Could have been Mr Thagard's wrong doing (couple of years later he did the A100 with stacked BJT/MOSFET output stages for Audio magazine single-handed, with a few pointers from Mr P)
Back in the late '80s and early '90s everyone was into triacs, me included, remote switching monaurals on/off with the preamp signal and a timer was comfortable.
Not very Audio-Pile nowadays, other more elegant ways.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 17th July 2012, 03:34 PM   #18
Still noisy compaed to other soilutions, I cannot remember when I last did a board with a triac, possibly 15 years ago, look at dimmer switches, yes they are a bit better these days than the RF transmitters they use to be, but why add anything that could add noise, when everywhere else we try to reduce it.
Old 17th July 2012, 03:54 PM   #19
indianajo's Avatar
Thanks for the circuit. Peavey doesn't have this pcb on the schematic on eserviceinfo.com and since this is working okay I really didn't want to pull the board out and trace it out to understand it. See, no diode on the trigger- learned something.
Old 17th July 2012, 04:53 PM   #20
tauro0221 is offline tauro0221  United States
What about using the MOC3061. This will power up the amplifier clean since it is start at zero crossing of the AC. Attached it is the technical data. Also you can use a zero crossing relay Omron G3NE-220T-US. I found it no too long ago I am planning to using it in my new design.
Relay or switch mainsHide this!Advertise here!
Mains relay help please :D 6L6 Power Supplies 9 31st May 2012 04:02 PM
Mains Relay blowing Fuse on GC k3ys3r_soz3 Chip Amps 2 6th March 2007 05:25 PM
cap across mains switch? klitgt Power Supplies 4 11th December 2006 08:27 PM
Never try to switch 450V DC at 3A with a conventional mains switch... Eva Power Supplies 28 1st November 2006 09:24 AM
Mains Switch Problems Angel-Baby Solid State 4 23rd March 2004 06:42 PM
