Sanken LEXAM SAPM01 audio transistors
Too early for datasheets. There are only press releases to be found on the net. Distributor in Europe is Allegro Microsystems
It's very easy to temperature compensate a complementary set of Power MOSFET's like IRFP240 / IRFP9240.
You can either use:
1..A small MOSFET like IRFP614I with 2 resistors and a trimmer on the gates, much like a normal BIAS transistor in a bipolar output stage, or :
2..exploit the fact that the derating factor of an IRFP is roughly the same as a normal Vbe (2,2 mV / K). Use a constant voltage source, and a Vbe doubler with a bipolar transistor (2N2222 or BC548) and you'll be all set!
These devices are great fun to build with, but their Rs varies a great deal with load, so you must find a way to compensate for that in your amplifier circuit. (if you want good sound - preferably without feedback loops).
