Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Help Identifying a Motor
Old 22nd June 2012, 04:02 PM   #1
angsuman is offline angsuman  United States
Default Help Identifying a Motor
Hi everyone. It's been a long time since I've posted, but I need help identifying a motor. I've been tasked with restoring this old moving artwork at my school. There are these strange motors that move a drumstick and hit it on a drum.
The motors have very limited travel, they only rotate about 45 degrees. There is a hairspring that provides restoring force for the motor.
I have attached a few pictures. There is a plate that mounts on the surface and is connected to the hairspring. I took the plate off and wasn't able to put it back correctly.
I really appreciate the help in identifying the motor. Thank you.
Old 22nd June 2012, 04:06 PM   #2
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
Those are rotary solenoids. If you Google the term, you'll find lots of information.
Frank
Old 22nd June 2012, 04:10 PM   #3
Thank you so much. I just didn't know what to even look for.
Old 22nd June 2012, 04:10 PM   #4
You're welcome. Good luck.
Frank
Old 22nd June 2012, 04:17 PM   #5
kevinkr's Avatar
Originally Posted by angsuman View Post
<snip>
<snip>
Plate now facing the wrong way?
As Frank says they are rotary solenoids.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Help Identifying a MotorHide this!Advertise here!
Belt driven Synchronous Motor vs. DC Motor for Record Players tiefbassuebertr Analogue Source 11 27th September 2013 05:38 PM
Compact Disc Motor and Turntable - Advices for Replace and Motor Service wanted tiefbassuebertr Digital Source 5 2nd August 2010 09:19 AM
Help required for using a FDD motor as a turntable motor. binspaul Analogue Source 5 13th May 2009 03:59 AM
Lambda motor vs. XBL^2 motor vs. any other motor Thinkcat Subwoofers 16 23rd December 2008 06:23 AM
DIY TT: motor, motor PS, platter speed measurements dice45 Analogue Source 52 9th May 2006 01:07 PM
