| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have a DPDT switch which will be used to turn on/off an amplifier connecting to a PCB board. The PCB board has 4 holes for the switch marked S1-(2 holes) and S1+(2holes). The DPDT switch has 6 contacts marked 1,2,3 on top and 1B,2B,3B on the bottom.
So; I just want to know which four contacts on the DPDT switch will go to which holes on the PC board. Switches always confuse the heck out of me. I just don't want to mess it up. Thanks for any help. |
#2 |
Are you just trolling ?.
An ohm-meter will tell you all you need to know. Eric.
I believe not to believe in any fixed belief system. |
#3 |
Use the two center contacts as one pair (i.e., 2 and 2B), then pick either set of contacts at the end for the other(say, 1 and 1B). If you don't like the direction the switch ends up pointing, you can either move the two leads at the end to the other end or you can loosen the switch mounting nut and rotate the switch.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#4 | |
#5 | |
Phil |
| Using a dpdt switch as on/off? | haakok | Parts | 6 | 3rd May 2009 05:55 PM |
| Help with switch selection and wiring... | illacov | Parts | 1 | 14th October 2008 04:06 PM |
| LM3886 and DPDT switch | Dino-Indo | Chip Amps | 4 | 6th July 2008 04:53 AM |
| Looking for dpdt switch | jeff5x0 | Parts | 2 | 28th February 2006 08:35 PM |
| HVDC DPDT Switch | Jack Thomas | Parts | 4 | 31st July 2002 12:16 AM |
| Page generated in 0.10194 seconds (65.33% PHP - 34.67% MySQL) with 10 queries |
