damage to petp caps - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th June 2012, 10:14 AM   #1
Default damage to petp caps
i'm suspecting that i might have damaged the russian k71-16 petp cap from too long a soldering.
is it possible for the polystyrene cap to retain value but lose dc blocking capability from heat damage? and do you think damage from soldering could occur to large value caps such as 22uf?
Old 17th June 2012, 11:37 AM   #2
What tests or symptoms lead you to the tentative conclusion that you have damaged your capacitor?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th June 2012, 02:37 PM   #3
a suspicion is not a conclusion.
Old 17th June 2012, 02:41 PM   #4
No symptoms and no tests then?
regards Andrew T.
Old 17th June 2012, 03:29 PM   #5
kevinkr's Avatar
Start by measuring leakage current and capacitance to know whether or not it is damaged..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 17th June 2012, 04:12 PM   #6
Speedskater's Avatar
a] Polystyrene capacitors are not available in large values like 22uF.
b] The DC resistance of a polystyrene capacitor is just about infinite.
c] Polystyrene capacitors are easily damaged/destroyed by overheating when soldering.
Kevin
Old 17th June 2012, 04:45 PM   #7
What does petp stand for?
regards Andrew T.
Old 17th June 2012, 05:18 PM   #8
Elvee is offline Elvee  Belgium
Elvee's Avatar
Polyethylene-terephtalate, AKA mylar, AKA polyester, AKA Hostaphan, etc
Quite heat-resistant compared to many polymers, particularly polystyrene
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 17th June 2012, 06:15 PM   #9
Jadran's Avatar
PETP are not polystyrene caps. but
Metallized Polyethylene Terephalate-Film Capacitors
and are well available at 22uF, for example 63V PETP Capacitors K73-16
it seems PreSapian made a mistake at opening post?!
Old 18th June 2012, 01:42 AM   #10
oops. thank you gents. seems that mistake is a common one for a lot of places list k71-16 as polystyrene.
work stress had making me thick headed for the last week. haha please forgive me.
Petp Capacitors-one Of The Best? audiojoy Parts 334 22nd December 2016 07:47 AM
water damage timwebb Car Audio 5 5th July 2010 03:09 AM
Flux Damage jkeny Parts 11 26th March 2008 04:57 PM
I think i finally did some damage Deagle50ae Multi-Way 1 18th April 2005 05:26 AM
Damage recovery Reklats Chip Amps 1 31st March 2005 02:42 AM
Copyright ©1999-2017 diyAudio
