Old Yamaha VU meters - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th June 2012, 07:09 AM   #1
diybass is offline diybass  New Zealand
Default Old Yamaha VU meters
Hey guys, I'm currently fixing and cleaning an old Yamaha MC1602 Mixer for a friend. One of the analogue VU meters is not working (among other things), so I was looking at getting a new meter to replace it. I have found one, but I am not sure if it is right for the job. Here is the link:
Buy Analogue Panel Ammeters Meter,panel,VU,moving coil,SQ10S Anders Electronics SQ10S online from RS for next day delivery.
I don't know much about VU meters, so I would appreciate all the help you guys could give me. Cheers.
Old 13th June 2012, 08:13 AM   #2
pinkmouse's Avatar
Have you contacted Yamaha? They have an excellent spares service.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 13th June 2012, 08:38 AM   #3
I have sent a request to Yamaha, I am awaiting reply.
Old 13th June 2012, 04:07 PM   #4
The SQ meter literature state that they are VU meters, but that could just refer to the scale. I did not see anything about the ballistics of the movement. Also, you do not know if the original movements are ballistically (is that a word?) correct or if the response is realized in the electronics. Than is also the question of the impedance matching of the meters...
Go with the original or replace both and use the good meter as a reference for alignment. E
Old 13th June 2012, 04:29 PM   #5
KatieandDad's Avatar
A meter is a meter. It is the scale that is non-linear.
Old 13th June 2012, 04:36 PM   #6
So, than, by this analogy, a transformer is a transformer, just the size differs (or the paint-job)? E
Old 13th June 2012, 04:45 PM   #7
Yes, you could use that analogy.
All meters are ammeters. A small current though the coil will cause the meter to move.
Adding resistors in series with the meter turns it into a voltmeter. Adding resistors in parallel will turn it into an ammeter.
They are all linear though. It is the dial which makes them non-linear.
Old 13th June 2012, 06:02 PM   #8
I was not referring to the basic function of a movement, but its behaviour (ballistics) as shown in the attachment. E
Old 14th June 2012, 12:00 AM   #9
Enzo is offline Enzo  United States
ACtually the mechanics matter too. A voltmeter per se just reads out some voltage. A VU meter, in contrast, is supposed to indicate in real time a changing signal. In the old days, they made special meters for VU display that had a certain mechanical response, a certain inertia, so they didn't fly around and were better able to indicate more of an average while still showing peaks. SO replaing a 50ua VU meter with a plain old 50ua meter movement might not be as accurate.
Discussions of VU meters usually breaks down into camps debating impedances etc. SO a difference must be made between a VU meter as a piece of equipment and a VU meter as in the indicator on the panel of some unit. The piece of equipment should have a certain impedance and move in a predictable manner. The VU panel meter is part of an overall circuit which determines all those things and as such is not so constrained.
Old 18th June 2012, 01:45 PM   #10
IF you know the brand i have a few emico ones
thanks
bob
VU-meters Cobra2 Swap Meet 3 13th November 2011 09:09 AM
VU meters Mace_Hacker Solid State 13 6th November 2009 05:43 PM
VU Meters Weston Tubes / Valves 15 3rd August 2008 01:45 AM
VU Meters owel Parts 14 26th March 2004 04:39 PM
VU Meters KenP Parts 6 9th October 2002 10:18 AM
Copyright 1999-2017 diyAudio
