Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Motor run capacitor
Motor run capacitor
Old 16th June 2012, 10:53 AM   #11
fpitas is offline fpitas  United States
Originally Posted by davidsrsb View Post
No, they are designed to run om mains supply and fail safe, so they often use evapourated metal film rather than foil, with fairly high ESR, so that a pin hole blows open. The dielectric is good, but there is a relatively high ohmic loss.
Still a much better dielectric than any electrolytic though.
Yes, they are film rather than foil, but they are also rather large physically, so there's plenty of surface area. I'll agree a foil cap of that size would beat these on ESR.
Old 16th June 2012, 02:39 PM   #12
a.wayne is offline a.wayne  United States
Sin Bin
Why use these as bypass over poly's ...?
Old 16th June 2012, 03:44 PM   #13
Navyblue is offline Navyblue  Singapore
They tend to be quite a bit cheaper than "regular" film caps?
Old 16th June 2012, 03:45 PM   #14
Originally Posted by fpitas View Post
Sounds like the same cap (and maybe the same seller). The part number on mine is 27L781.
Yup, I guess we got the same cap from the same seller.
Old 17th June 2012, 10:18 AM   #15
davidsrsb is offline davidsrsb  Malaysia
Yes, they are made for the low markup "industrial" market, not the "boutique audiophile" one and therefore affordable. The performance should be fine for a crossover or valve amp supply filter.
Old 17th June 2012, 11:42 AM   #16
R.I.P.
Motor run capacitors come in both plastic film type and electrolytic type.
The electrolytic are generally much smaller than the film type of the same value. And much cheaper.
regards Andrew T.
Old 17th June 2012, 11:44 AM   #17
At least in the States, only the motor-start seem to be electrolytic. All the motor-runs that I found datasheets for were polypropylene.
Old 19th November 2012, 06:16 PM   #18
Captn Dave is offline Captn Dave  United States
Originally Posted by Tony View Post
voltage ratings for one, the ac voltage translates to about x1.4 dc, so if you have a 220vac cap, you are good to go for 308volts dc....
As you noted, the rating for that cap is stated as volts RMS in the data sheet. I was looking at a Temco data sheet and they didn't specify a rating. I called and asked. They rate theirs peak to peak! In their video they even suggest using a 600v cap in a 440v service. Kind of shocking...
The take home here is that one should not assume to operate all motor run caps at 1.41 times name plate voltage until you read the data sheet.
Motor run capacitorHide this!Advertise here!
Motor run caps? albireo13 Tubelab 12 5th March 2010 08:35 AM
motor run caps grahamb Parts 3 17th September 2009 11:14 PM
motor run capacitor milen007 Parts 12 28th June 2008 05:49 PM
Motor Run Capacitor Zap Parts 2 14th May 2008 09:59 PM
Dumb motor run capacitor question chrish Parts 5 14th August 2007 09:25 PM
