LM350 question - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th October 2003, 11:00 AM   #1
Ralph is offline Ralph  Netherlands
Ralph's Avatar
Default LM350 question
Working conditions are specified with Vin-Vout >= 3V. Does the regulator work better if I leave it let's say 4 or 5 Volt to work with?
My Vout is 5V @ 1.4A btw.
Old 10th October 2003, 11:03 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
Yes, under 3 V the regulator won't regulate. Calculate for worse case situations, low mains voltage and high load from the regulator. Don't forget about the ripple voltage also!
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 5th November 2003, 06:02 AM   #3
EE_Mark is offline EE_Mark  United States
Default Dropout voltage
3 volts is the bare minimum they spec. They seem to work at slightly less than 3 volts but you're asking for trouble if you do that. 4 or 5 volts would be much better but remember the power dissipated in the regulator is the voltage across it times the current flowing through it. The LM350 is supposed to shut down if it goes too hot so at least it won't destroy itself. If you put in 10 volts and get out 5V@1.4 amps the regulator will dissipate 7 watts. Be sure and use a heatsink.
Mark
Old 5th November 2003, 08:45 AM   #4
Ralph's Avatar
I'm measuring 9,36 - 9,56 Vdc (depending on time of day) on Vin, so that looks good enough. (for 5V out)
Old 7th November 2003, 05:03 PM   #5
djmiddelkoop's Avatar
Ralph,
the input you measure is OK, but like Peranders said, don't forget the ripple voltage ( rimpel in nederlands ). This mainly depends on the size of your capacitor. If the ripple is 2Vtt you have to subtract 1V from the input you measured. In this case you are still ok, because you are above the 8V ( 5 +3 ).
For 1.4A out I would use 2200uF to be save.
Dick.
“Information is not knowledge Knowledge is not wisdom
Wisdom is not truth Truth is not beauty Beauty is not love Love is not music Music is THE BEST”
Old 7th November 2003, 05:29 PM   #6
Ralph's Avatar
Thanks Dick,
I measure very little AC on the input of the LM350 and use a large cap, so it must work out nicely. Thanks
LM350 Based Variable PSU Problem hernanstafe Power Supplies 0 27th April 2007 05:39 PM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
LM350 adjust pin eeka chu Solid State 3 5th February 2004 11:08 AM
Capacitor Question /question on cap TunaFish Parts 14 12th January 2004 02:23 AM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Copyright ©1999-2017 diyAudio
