Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th May 2012, 02:33 AM   #1
john dozier's Avatar
Default BNC male to BNC male adapter
I am trying to find a BNC male to BNC male adapter with teflon insulation. All the ones I find have Delrin. I did find one supplier for adapters with teflon insulatin, but they want a $50 minimum order. Anyone know of a supplier who will supply just one? Thanks
Evil looms. Cowboy up. Kill it. Get Paid.
Old 29th May 2012, 02:44 AM   #2
Pano is offline Pano  United States
Pano's Avatar
That's a tough one. The male to male BNC is rare, don't think I've ever seen one. The Female-female BNC barrel is much more common.
Makertek sells them, but no specs.
Old 29th May 2012, 02:48 AM   #3
I may just have to spring for the $50 minimum, but I really do not want to. But at least I know I am getting what I want. Regards
Old 29th May 2012, 02:50 AM   #4
Pano's Avatar
What you gotta do? I can't picture what you'd use it for. Unless you have a cable with a female end that you need to turn around.
Old 29th May 2012, 02:53 AM   #5
It is to mate a jitter reduction device directly to a DAC input. It's to keep cable induced jitter to a minimum. Regards
Old 29th May 2012, 02:58 AM   #6
Pano's Avatar
Got it, makes sense thanks! A BNC cable without the cable.
Old 29th May 2012, 03:04 AM   #7
gootee is offline gootee  United States
Narda? Pasternak? MCM (I think it is)?
Why don't you want to use the ones with Delrin?
Old 29th May 2012, 10:41 AM   #8
DF96 is offline DF96  England
How fast is the DAC receiver? Provided your connection transit time is significantly shorter than the receiver response time it should not matter how much shorter it is. There is an argument that a longer cable can reduce jitter, because it gives more attenuation of reflections.
Ideally, your jitter reduction device should be next to the DAC on the same PCB. Even then you have PCB traces acting as transmission lines.
Old 29th May 2012, 12:11 PM   #9
SY's Avatar
As long as the impedance is 75 ohms, why on earth would Delrin be a problem? It's mechanically much sounder than Teflon.
If there's a sucker born every minute, where do the rest of them come from?
Old 29th May 2012, 12:25 PM   #10
BNC only works up to 3GHz, so obviously marginal for audio. Maybe we should start a trend to SMA (10GHz)?
M2Tech Hiface - Why not female USB to male BNC/RCA instead? orpheus PC Based 16 5th August 2010 08:24 PM
Adapter for Ipod to stereo jack (Male) rossparry Car Audio 3 2nd December 2009 07:14 PM
WTB: BNC male connectors Jimmy154 Swap Meet 0 9th November 2005 03:11 PM
So using a BNC-to-RCA adapter is a bad idea? KT Digital Source 24 3rd May 2005 09:45 PM
XLR 4pin to 3 pin male adapter kevinhero Parts 3 18th November 2003 01:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
