BNC male to BNC male adapter - Page 4 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 30th May 2012, 06:50 PM   #31
RJM1 is offline RJM1  United States
No, It's not the diameters of the cables but the ratio of the inside diameter to the outside diameter and the dielectric constant of the insulator. This is the problem, if you keep the physical ratio of the inside and outside conductors the same you must change the dielectric constant of the insulator to match the impedance to 75 ohms. What they did to compensate for the change needed in the dielectric constant was to add an air gap which reduced the high frequency response. 75 ohm tnc. Amazon.com: 75 Ohm TNC Female Crimp for RG59 Cable: Electronics
Old 30th May 2012, 07:19 PM   #32
DF96 is offline DF96  England
I'm not saying it is the cables, I was just using that as an example of geometric change which apparently preserves impedance yet still creates reflections. I think it is unlikely that an airgap will reduce HF response as air is a fairly good dielectric, unless it is just the discontinuity which is the problem.
Old 30th May 2012, 08:12 PM   #33
Pano is online now Pano  United States
Pano's Avatar
It's the standard way to tell 75 ohm from 50 ohm BNC. Look at the center pin. 50 has insulation around the pin, 75 does not.
Old 30th May 2012, 08:44 PM   #34
AndrewT is online now AndrewT  Scotland
Let's take a 50ohm M & F connector and a pair of 50ohm cable ends designed to be compatible with the connector.
They will have a bandwidth that works within a tolerance.
Now replace all those 50ohm components with 75ohm components, again with compatibility between connector and cable.
Why does the 75ohm connection version lose 10GHz of bandwidth?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 30th May 2012, 08:56 PM   #35
The thing is they didn't change the size to make it compatible the just fudged it.
Old 30th May 2012, 09:08 PM   #36
Changing the dielectric changes the impedance. That was explained a little earlier.
Introducing a thinner dielectric and using air for the remainder also changes the impedance.
That introduction of the air to replace the missing dielectric does not help explain the missing 10GHz.
There's something else you are not telling me.
regards Andrew T.
Old 31st May 2012, 01:42 PM   #37
macboy is offline macboy  Canada
Go back and read carefully. RMJ1 explained that all TNC connectors are 50 ohm, even when used with 75 ohm cable in a 75 ohm system. The impedance mismatch causes issues (poor SWR) above about 1 GHz. Below that point, the mismatch occurs over a small enough length of the transmission line that there is little effect. At higher frequencies, the physical length of the impedance-mismatched portion (the connectors) is bigger relative to the wavelength of the signal in the transmission line, so it has more impact.
Getting back to BNC, these are commonly available in 75 ohm, but even then they perform worse than the 50 ohm versions. This is due to an air gap in the dielectric which is required to provide the 75 ohm impedance from a connector whose dimensions were originally chosen to provide 50 ohm impedance. BNC is also generally not used above a few GHz anyway since the slots can start to radiate signal. The TNC is mostly identical but is threaded so it does not have this problem. Regardless, this is SPDIF and the driver circuits simply do not have the slew rate to provide GHz range signal components.
Old 31st May 2012, 04:40 PM   #38
john dozier's Avatar
So gentlemen, what sort of "bullet" will provide the least signal degradation at spdif frequencies and 75ohm output and input? Could you specify type of connecter, type of insulation, and metal content. Thanks
Evil looms. Cowboy up. Kill it. Get Paid.
Old 31st May 2012, 04:47 PM   #39
SY's Avatar
Any 75 ohm BNC which isn't defective will not degrade an spdif signal (the GHz discussions were academic, not practical- these are hundreds to thousands of times higher than spdif frequencies). If you stick to a name brand (e.g., Amphenol) purchased from a reputable distributor (e.g., Mouser), the signal transmission will far and away not be limited by the connector.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 31st May 2012, 07:51 PM   #40
I agree with SY, BNC is an excellent interconnect and should work very well for this purpose. Make sure to stick with 75 ohm, and don't bother too much with teflon or such. The 75 ohm ones can be identified visually, so look into that (try here). Don't be too surprised if the BNC input or output jacks on your gear are not 75 ohm!
I also agree with sticking to name brand stuff, I bought some cheap BNC T's off eBay and they are garbage.
M2Tech Hiface - Why not female USB to male BNC/RCA instead? orpheus PC Based 16 5th August 2010 09:24 PM
Adapter for Ipod to stereo jack (Male) rossparry Car Audio 3 2nd December 2009 08:14 PM
WTB: BNC male connectors Jimmy154 Swap Meet 0 9th November 2005 04:11 PM
So using a BNC-to-RCA adapter is a bad idea? KT Digital Source 24 3rd May 2005 10:45 PM
XLR 4pin to 3 pin male adapter kevinhero Parts 3 18th November 2003 02:09 PM
Copyright 1999-2017 diyAudio
