Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Need cap help for Adcom GTP-600 Tuner/Pre-amp
Old 27th May 2012, 05:17 PM   #1
penr0295 is offline penr0295
Default Need cap help for Adcom GTP-600 Tuner/Pre-amp
When I got this GTP-600 it would only tune stations 105 thru 107. I found a helpful post that said that the culprit was often variable capacitors CT101, CT102, CT103, and CT104 (indicated with red arrows in attached image). Indeed, after turning them back and forth and using some DEOXIT, everything immediately began to work perfectly. However, every couple of weeks the tuner fails again, and I have to take the cover off and do the same procedure, turning them back and forth, and using DEOXIT. This has been going on for a couple of months now.
Any ideas of what might make the fix longer lasting, or do I just need to replace them? And, would it be likely that I could find the exact same caps through a supplier, to make it easier for me to swap them out?
Old 27th May 2012, 07:14 PM   #2
stellavox is offline stellavox  United States
I would suspect a bad solder joint somewhere in the neighborhood of the trimmer caps. Can you get at the bottom of the board and "touch up" the connections (look first and see if you find anything "suspect"
Charles
Old 27th May 2012, 07:19 PM   #3
Yes, I should be able to do that. I will make it the next thing I try. Thanks.
Old 28th May 2012, 03:55 PM   #4
Ronsonic is offline Ronsonic  United States
DeOxit is wonderful stuff and I use it on everything except the wife .....
But it isn't the tool for this job. You need a "tuner cleaner" that leaves no residue at all. Variable caps are susceptible to any sort of contamination.
Old 7th June 2012, 06:06 PM   #5
The GTP600 stopped working again, so I used that opportunity to remove the circuit board and touch up the solder connections for the caps. Put the board back in, without rotating the caps or etc., and it has all worked fine since. So, hopefully it was just a broken or cold soldered connection, and the problem will not happen again. I have really liked this tuner.
Old 5th February 2014, 03:35 PM   #6
steelyjoe is offline steelyjoe
THANK YOU penr0295
Need cap help for Adcom GTP-600 Tuner/Pre-ampHide this!Advertise here!
FS Adcom GTP-600 Preamp/Tuner tomeh! Swap Meet 1 30th April 2011 06:51 PM
Adcom GTP-500 Preamp/Tuner xecluded Swap Meet 1 30th April 2011 06:48 PM
FS: Adcom 5802 Amp and GTP-502 Pre Zero Cool Swap Meet 0 10th December 2009 03:33 AM
Adcom GTP-502 Tuner/Preamp $150 Zero Cool Swap Meet 2 8th September 2009 09:58 PM
adcom gtp 500ll tuner problem, Nelson Pass maybe? crippledchicken Pass Labs 11 22nd January 2004 12:36 AM
