Field spotter's guide to capacitors - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th October 2003, 03:38 PM   #1
weinstro's Avatar
Default Field spotter's guide to capacitors
This is hopefully a basic question.
I have some old Marantz amplifiers from 1980 or so that I wish to freshen up a bit.
There are several types of capacitors easily seen on the circuit boards. The technical manual indicates that they are "film" capacitors, and gives the appropriate value, but I'm not sure if these are polycarbonate, mica, tantulum, etc. I generally have no problem spotting electrolytics.
This would be helpful in terms of specifying suitable replacements.
Some look like green chicklets, and some look like a wad of magic tape. Any ideas?
Thanks and regards,
Rob
Old 8th October 2003, 04:13 PM   #2
OliverD is offline OliverD  Germany
OliverD's Avatar
Besides the value you don't need to know what Marantz put in there originally in 1980 as you will do better anyway. It more depends on the position in the circuit (AC signal coupling, PSU filtering etc.) what type fits best.
I belong to those who think that topology and active devices have the most influence on the sound. For the passive components, I use resonably priced high quality parts, nothing esoteric.
This is my personal capacitor selection guide, based on listening preference and local availability, valid for (pre-)amplifiers and other line level audio circuitry:
For the small electrolytics, I use "Panasonic FC" as I can get them at resonable prices. The bigger values (PSU) are "BC Components", series "154" or "051", sometimes "Roederstein EYS-07".
I don't use tantalum or ceramics in (analogue) audio.
For film type capacitor, my choice is as follows:
Up to about 10nF: Silver Mica, Styroflex (R) or Wima FKP-2, depending on budget and space available.
10 nF to 1F: Siemens MKH or various Wima types
above 1F (PSU filtering only): Wima MKP-10
above 1F (AC coupling): Replace by wire if possible, optionally add DC servo. If not possible, re-design circuit or ask the passive components gurus for a suitable esoteric part.
Hope this helps.
Field Guide to Identifying Components ? vonfilm Parts 6 20th October 2008 05:52 AM
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 01:38 PM
Near field vs Far field Audist Multi-Way 17 25th May 2007 08:44 PM
Near field / far field? 2litre Multi-Way 4 2nd January 2006 10:44 AM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 02:29 AM
Copyright 1999-2017 diyAudio
