Zeners - 2.4 - bad batch? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd April 2012, 09:12 PM   #1
akis is offline akis  United Kingdom
Default Zeners - 2.4 - bad batch?
I have a batch of 12 Zeners 2V4 - and they all exhibit a strange behaviour. A Zener will typically pass no current until it reaches its breakdown point and then it will start to conduct, and the voltage will remain more or less constant. However those 2.4V Zeners, they conduct immediately at any tiny voltage and then the voltage increases until it goes past 2.4V and keeps rising. Any ideas what I am looking at?
Old 24th April 2012, 07:52 AM   #2
Elvee is offline Elvee  Belgium
Elvee's Avatar
What is their type N°?
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 24th April 2012, 09:52 AM   #3
2V4 zeners have a very soft "knee", leaking a lot below the nominal voltage and poor regulation above the knee. A forward biased green LED can give a sharper reference
Old 24th April 2012, 09:53 AM   #4
BZX79-C2V4
Old 24th April 2012, 10:09 AM   #5
Elvee's Avatar
Looks normal:
http://www.nxp.com/documents/data_sheet/BZX79.pdf
They are the lowest voltage in the series, and low voltages zeners tend to have dismal characteristics: at 1V, they already pass 50µA, and their dynamic resistance at 1mA is between 275 and 600 ohm.
They could be called "Slightly Non-Linear Resistors" instead of zeners.
At these voltages, stabistors perform probably a little better: the theoretical dynamic resistance for this voltage would be in the region of 150 ohm.
Old 24th April 2012, 11:41 AM   #6
I have now used a yellow LED followed by a 1N4148 to get the voltage drop - as shown here. I added the 1N4148 because the sinusoidal looked crooked on the oscilloscope without it.
SPICE batch line commands? hahfran Software Tools 2 2nd March 2010 09:06 AM
Batch PCB production for Diyers Batchpcb4Diyers Vendor's Bazaar 4 6th April 2009 08:18 AM
AD826AN - bad batch? pftrvlr Digital Source 9 30th October 2008 01:36 AM
Should I use high voltage value zeners or multiple lower voltage zeners in series? jarthel Parts 7 30th May 2006 04:56 PM
Batch of heatsink FrankDIY Swap Meet 1 19th March 2004 01:43 AM
Copyright ©1999-2017 diyAudio
