Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Replace Shoei capacitors?
Old 20th April 2012, 02:03 PM   #1
zerotohero is offline zerotohero  New Zealand
Default Replace Shoei capacitors?
I'm currently upgrading/modding my nakamichi ec100 active crossover and separate power supply.
It has light blue "shoei" caps in both the crossover and the power supply but I cant find any info on the net about them.
I want to upgrade them if they are not very good but unsure to what?
Anyone have any info on this brand?
Old 20th April 2012, 02:15 PM   #2
Conrad Hoffman is offline Conrad Hoffman  United States
There's this constant desire to recap things and "upgrade" caps, with no real info on what's already in there. My advice is to measure what you've already got- value and loss, before lifting pads and traces and generally downgrading the whole unit. You can either buy a digital cap meter with loss (not that cheap) or build a simple bridge from a few parts (pdf on my site), or at the very least, buy or build an esr meter. That will only give you half the information, but probably the more important half, and you could combine it with any cheap DVM having a capacitance function. Without some actual data, one is just flailing in the darkness!
BTW, even if you had a datasheet, capacitors typically exceed their datasheet specs by so much that comparing paperwork doesn't tell you a lot.
I may be barking up the wrong tree, but at least I'm barking!
Old 20th April 2012, 03:30 PM   #3
Thanks for that.
I was hoping someone might know at least what league this brand of caps are in?
Old 20th April 2012, 03:47 PM   #4
ide2003 is offline ide2003  Indonesia
Hi, that light blue shoei solved hum problem in my dac dht tube out heater (1.25V), in my case 1uF/100V. put there before cerafine, mkt, mkp to no avail. I should bought more of them.
What league? I don't know, saw several of them in old (japan made) sony car amps, good enough I guess. (the ones near trim pot)
best, TeguhPS
Old 20th April 2012, 04:05 PM   #5
Yes, the light blue ones at the bottom of your pic are the same ones I'm talking about
Old 20th April 2012, 04:25 PM   #6
I see, many times 'logic' of using better part does not guarantee better result, although I might consider replacing these shoei in crossover/ signal path with film caps
Old 20th April 2012, 04:49 PM   #7
Ronsonic is offline Ronsonic  United States
Forget the brand, if it's functioning, not bulging and passes an ESR test then it's what it was supposed to be. Nak does not generally suck.
Like ide2003, I am happy to replace the small lytics you find in the signal path with film. Modern cap construction and the economics of DIY electronics doesn't leave much excuse for things like 0.47uF electrolytic coupling caps.
Mostly, subbing in audiophile approved brands just because doesn't help much.
Old 20th April 2012, 04:52 PM   #8
simon7000 is offline simon7000  United States
They are much better than average!
Old 21st April 2012, 12:39 PM   #9
Thanks, care to expand on that?
Replace Shoei capacitors?Hide this!Advertise here!
Replace / remove couple capacitors in Teufel decoderstation 3 maikel Analog Line Level 6 23rd May 2014 02:49 PM
Which capacitors should I replace? davidzhou Tubes / Valves 30 10th June 2010 05:42 PM
How can I understand if it is time to replace capacitors? beppe61 Parts 51 28th November 2005 11:00 AM
capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors costiss Parts 11 30th January 2003 10:32 PM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 02:29 AM
