How to test an old 60000uf cap ? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th April 2012, 02:56 PM   #1
kp93300 is offline kp93300  Malaysia
Default How to test an old 60000uf cap ?
My antique dealer friend gave me these 60 000 uF cap for me to diy.
My cap meter only measure up to 20 K uf.
I intend to use it in a +/_ 22 v dc power supply for the Death Of Zen amp drawing about 3.5 to 4 amp continuously.
How to test these cap before using it ?
I do not have a ESR meter and any simple circuit to test it ?
thanks
kp93300
Old 19th April 2012, 11:24 PM   #2
Enzo is offline Enzo  United States
Look up "capacitor forming" and do that to them first. Just to get them capacitating.
If you have a bench power supply use it, otherwise knock together a small power supply making 25-30 volts DC. COnnect a volt meter to the cap, and connect the power supply to the cap. That should charge the cap up to the supply voltage. Now disconnect the power supply from the cap. Monitor the meter to watch what the charge in the cap does. If it slowly drains away, that is a good sign. If it wants to just drop down fast and get out of town, that is no good.
Not very scientific, but no special gear required to perform this admittedly crude test.
Old 20th April 2012, 12:38 AM   #3
Thanks Enzo for a advice .
easy to follow and do.
kp93300
Old 20th April 2012, 01:35 AM   #4
cbdb is offline cbdb  Canada
Might be a good idea to put a small resistor between the supply and the cap incase the cap shorts (sometimes happens) The resistance large enough to limit the current to below the max supply current, it will also prevent the large inrush currents that a supply may not like to see.
Old 20th April 2012, 03:40 AM   #5
Good idea.
Old 20th April 2012, 04:22 AM   #6
If you want to really test it, there's a quick cap bridge that also does losses here that will go to 100,000 uF and just uses a few components. You could also measure the charge time with a known resistor and calculate the value. If you download Visual Analyser (free- Google it), it has a full LCR meter built in. All you need is the right interface to your sound card. Not sure how high it reads. They look like Sangamo. If they're old, check the leakage as well. Chances are they're good.
I may be barking up the wrong tree, but at least I'm barking!
Old 20th April 2012, 03:01 PM   #7
Default cap bridge
I read the link posted by Conrad.
I will try the circuit .
Please see the attached image .
What does this symbol mean ?
thanks
kp93300
Old 20th April 2012, 03:51 PM   #8
Pi
Old 20th April 2012, 04:32 PM   #9
Oh my god.
Old 20th April 2012, 05:11 PM   #10
john65b is offline john65b  United States
john65b's Avatar
Can't you could put another smaller known capacitance cap less than 20,000uf in series and re-measure total capacitance with your LC Meter??
1/Ct=1/C1 + 1/C2
EDIT - It's been a while, and I think I got that right.
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Dayton foil vs PPS cap listening test sendler Parts 8 1st March 2013 06:38 AM
Polar electro with bypass cap to replace nonpolar as coupling cap? at77 Parts 0 12th January 2010 02:05 AM
My little coupling-cap-test in a UL-70W-Amp Blitz Tubes / Valves 6 11th July 2009 04:55 PM
Tripath Coupling Bypass Cap Test Bed Query Davet Class D 4 9th January 2008 02:12 AM
Is there any test cd to test jitter using a scope ? gaetan8888 Digital Source 4 10th August 2007 09:24 AM
Copyright 1999-2017 diyAudio
