Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th April 2012, 05:26 PM   #11
KatieandDad's Avatar
As an absolute test then YES go down the Wheatstone Bridge route.
As a purely functional test go down the reforming route and do a simple test with a resistor.
All electrolytics will dry out in time. HOW LONG is anyones guess.
Try reforming them by applying 75% of their rated voltage through a limiting resistor.
Leave them at rated voltage for several hours.
Then discharge them through a known resistor and measure how long it takes them to discharge.
It takes approximately 0.7xRxC seconds to discharge a good cap to 75% of its charge.
THIS IS NOT EXACT but it is a reasonable test to see if they are OK or completely useless.
I forgot to mention, if the voltage across the cap never reaches the applied voltage then it is equally useless. (Care must be taken that the charging resistor isn't too large in value as the leakage current may exceed the charging current and the cap will never charge).
The best solution is to look at the datasheet and find out what the leakage current should be. If you don't know then it is a bit of guesswork. Charging at 100mA should achieve the desired results.
Old 21st April 2012, 03:23 AM   #12
kp93300 is offline kp93300  Malaysia
Originally Posted by john65b View Post
Can't you could put another smaller known capacitance cap less than 20,000uf in series and re-measure total capacitance with your LC Meter??
1/Ct=1/C1 + 1/C2
EDIT - It's been a while, and I think I got that right.
What a brilliant idea!
This is lateral thinking that i am lacking !
Thanks to john65b.
Hi KatieandDad
I try reforming the caps with 16 V dc power supply via a 1K in series. Initially , the V across the 1k is about 16 V and slowly drops as charging continues.
After 15 minutes, it is still charging and i shall aim for 100ma charging current .
thanks
kp93300
Old 21st April 2012, 09:14 AM   #13
0.7 x 60000 x 10e-6 x 1000 = 42 seconds.
If you are still charging after 15mins then you have a lot of leakage.
You will not get the full 16V across the cap. but you should get close and the voltage across the resistor should drop to reflectthe leakage current.
Old 21st April 2012, 10:32 AM   #14
If they haven't dried out they may recover after reforming - don't give up just yet.
Old 21st April 2012, 06:53 PM   #15
DDB is offline DDB  United States
Default Conrad's Large Cap Bridge
For those interested in Conrad's cap bridge, here is some additional info for a version I recently completed. The bridge worked very well at the 60hz frequency Conrad designed it for, but I wanted to try it at the 120 hz specified by most data sheets. This however compressed the DF readout and as I couldn't find a log taper 250 ohm pot, Conrad suggested a 25 ohm pot be substituted which was calibrated to give a .1 DF max reading. An additional switch in the top right corner was added to sequentially add 13.263 ohm resistors for an additional .1 DF per step. A total DF range now is 1.2 at very good resolution on the low end where needed. Since I also have a GR1656 bridge which measures caps to 1100u, this bridge is used for large values.
Old 2nd May 2012, 12:41 AM   #16
Just a word of thanks who post in this thread.
The cap is ok and is a great SQ improvement in my DOZ class A amp power supply filter.
Bass is effortless !
kp93300
Dayton foil vs PPS cap listening test sendler Parts 8 1st March 2013 06:38 AM
Polar electro with bypass cap to replace nonpolar as coupling cap? at77 Parts 0 12th January 2010 02:05 AM
My little coupling-cap-test in a UL-70W-Amp Blitz Tubes / Valves 6 11th July 2009 04:55 PM
Tripath Coupling Bypass Cap Test Bed Query Davet Class D 4 9th January 2008 02:12 AM
Is there any test cd to test jitter using a scope ? gaetan8888 Digital Source 4 10th August 2007 09:24 AM
Copyright ©1999-2013 diyAudio
