Which relay for audio? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th April 2012, 06:49 AM   #1
jeepy is offline jeepy  Switzerland
Default Which relay for audio?
Hello All, I have a bunch of small Teledyne 712 relays in TO39 pakage and also some big Clare HGR2M with wet contacts (mercury) relays. Are they any good for small audio signal switching from 2mv to 5V?
Thanks,
Old 12th April 2012, 06:54 AM   #2
analog_sa's Avatar
Dunno how good those are. Why don't you just put them in the signal path and take a listen? Surely this would be more valuable than the opinion of strangers with unknown hearing deficiencies
I like the Panasonic TQ2. Digi-Key Part Number 255-1002-5-ND
Old 12th April 2012, 09:00 AM   #3
PChi is offline PChi  United Kingdom
In my opinion any relay design for small signal switching should be OK.
The Panasonic TQ2 contacts are gold plated which is good for small signal.
The Teledyne relays also look good, they are using gold contacts.
I prefer and have used reed relays where the contact is sealed from the outside world to prevent contamination.
The problem with general purpose relays is that after time the contacts can go high resistance when switching small signals. When switching a few volts they are OK because I presume the volts and current break through the oxide. I think that they use silver plated contacts which oxidise, OK for power but non ideal for small signal. The trouble with gold plating is that it isn't very durable so isn't good for power relays.
I don't know about mercury relays. I don't think that they are necessary and I am not to keen on using the metal. Interestingly it is OK now to use it because it is 'Green' or at least someone has made money out of manufacturing / subsidies for flourescent lamps.
Cambridge Audio A3i Relay BradNad Solid State 17 25th September 2015 10:12 PM
WTB: Audio Signal Relay gabanyayaya Swap Meet 1 10th April 2011 01:01 PM
Relay Question on PS Audio 200c Pure_Brew Solid State 9 29th May 2010 01:26 AM
Switching audio signals with relay niral622 Solid State 11 19th April 2004 03:28 PM
Audio amplifier output relay delay PH Solid State 5 18th April 2004 04:55 PM
Copyright 1999-2017 diyAudio
