Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd October 2003, 02:12 PM   #1
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Default Recommendation for metallic paint that can be used on wood
I'm quite impressed by ingenuity of this design here: http://www.coasterreview.com/phono/?...ze=725&start=0
This pretty much allows to build a wood chassis and paint it inside to shield (instead of using metal foil or plates). It makes a nice box to house preamp or a DAC. Any ideas what kind of paint can do the trick?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 2nd October 2003, 03:17 PM   #2
JOE DIRT®'s Avatar
Peter I dont know if this is what your looking for but there is a paint called STEEL-ITE it is heavily impregnated with particles and is very corrosive resistant...we used it extensively in the food industry on anything that had to be painted......you can get it in an aerosol or can....most industrial places carry it.....the finish is brilliant with a spray can
DIRT®
Old 2nd October 2003, 03:23 PM   #3
The paint I'm looking for, has to be conductive.
www.audiosector.com
Old 2nd October 2003, 03:30 PM   #4
UrSv is offline UrSv  Sweden
UrSv's Avatar
This is fairly standard and used among other places by Advantage as they use plexi for covers (or used before). I think it is copper or bronze paint usually.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 2nd October 2003, 03:58 PM   #5
Default Re: Recommendation for metallic paint that can be used on wood
This pretty much allows to build a wood chassis and paint it inside to shield (instead of using metal foil or plates). It makes a nice box to house preamp or a DAC. Any ideas what kind of paint can do the trick? [/B][/QUOTE]
EMC Nickel based spray from Farnell ot RS. Not cheap; I'd rather used copper/st steel sheets.
Old 2nd October 2003, 04:11 PM   #6
What about boat paint like this one just like $54 a quart
Hard Copper Bronze Bottom Paint / Quart - SGKS960Q
http://sgksclassicboatstore.zoovy.co....bottom_paint/
/Magnus
Helpless in US
Old 2nd October 2003, 04:50 PM   #7
Ever think of Copper RF shielding tape. It's the same size as duct tape & you can soldier it town to ground traces. Much thicker & better than you will ever get from conductive paint.
_______
Brian
Old 2nd October 2003, 05:15 PM   #8
seangoesbonk's Avatar
This is exactly what you are looking for...
http://www.mgchemicals.com/products/841.html
My girlfriend's sub is bigger than mine...
Old 2nd October 2003, 05:15 PM   #9
I've got both aluminum and copper shielding tapes, as well as mu-metal sheets, but use of paint seems like a more elegant approach. It also shouldn't affect much the properties of wood, if you believe it has any influence on the sound. It is definitely worth trying, also much easier to apply (paint).
The way the whole assembly is done (in the pictures) is quite amazing (at least to me).
www.audiosector.com
Old 2nd October 2003, 05:19 PM   #10
Default Re: Re: Recommendation for metallic paint that can be used on wood
Yes, thanks.
www.audiosector.com
Kimber Kap metallized polypropylene capacitors! lanchile07 Chip Amps 0 16th January 2008 08:37 PM
Paint steel chassis with the "aluminum paint" used on wire fence? vax9000 Tubes / Valves 2 23rd July 2006 01:14 AM
I'm looking for inexpensive conductive paint... Few Planars & Exotics 14 13th May 2006 02:12 AM
Leclanche 1µf/1kV Metallized Polypropylene WALTER BURKHARD Swap Meet 1 16th January 2004 10:19 PM
Page generated in 0.09205 seconds (86.38% PHP - 13.62% MySQL) with 10 queries
