| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
I swapped that transistor and dont have anything change. Same as before, the relay has no voltage and the receiver isn't doing anything like it was before.
So this is what the receiver is doing. It wont light the standbby light, atleast not that I can see, it wont power up, and for all intents and purposes its dead. Except, it will run the fan for ~3 seconds when you plug it in (not when you power it on) and there is a very dim lighting of the digital read out - you can make out what it says but you unplug it it goes off and plug it in and it lights up very very faintly, maybe all the led's are comming on. So what could be happening. I received this in the same dead condition I have it in now. So I cant say what killed it. Thanks guys. Srinath. |
#12 |
What exactly does that relay do ? I have a yamaha rx-v795 that also has that relay clicking on then off in a fraction of second. I had a denon 3802 that had the same thing happen, and I removed it and re fitted it and it works.
So I am a bit stumped, what exactly does it do. Thanks. Srinath. |
#13 | |
The 3 connector that is going to NAR-6332, that has the +13v dc I am supposed to have. However there is no voltage @ the coils of the relay RL-901 and I have shorted the prongs, so its like the relay is connected. The amp still has nothing lighting up, and its not even going to stand by when I plug it in. What could be wrong ? Thanks. Srinath. |
| Using Many Small Signal Transistors Paralleled in place of one output Transistor | John Biles | Solid State | 37 | 8th January 2013 12:54 AM |
| MPS8050 NPN Transistor | RJohns777 | Car Audio | 0 | 20th January 2012 09:21 PM |
| small signal transistor | icko | Solid State | 13 | 13th May 2009 01:01 AM |
| How to matching PNP with NPN Transistor | senee | Solid State | 16 | 7th March 2005 11:12 PM |
