Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
TL072 opamp replacement
Old 12th April 2012, 07:19 PM   #11
jabba217 is offline jabba217
I just got my NE5532p----it's the wrong size. I'm talking physical size. the chip isn't big enough to fit the eight legs in the holes in the circuit board. What do I need?
Old 12th April 2012, 07:32 PM   #12
diyAudio Member RIP
Again ?
The standard part should fit. This won't :
rgds, sreten.
Old 12th April 2012, 08:28 PM   #13
phaselag is offline phaselag  United States
You had an 8 pin dip. The replacement is a surface mount SO package. You can either solder short wires on the SO chip, or buy another 5532 in an 8 pin DIP package. It is a standard package that is available.
paul
Old 12th April 2012, 09:58 PM   #14
Originally Posted by sreten View Post
Again ?
rgds, sreten.
My part looks exactly like the top picture. The one I'm replacing looked the same but was nearly 1 1/2 times bigger.
Old 13th April 2012, 09:36 AM   #15
peelaaa is offline peelaaa  Ireland
Originally Posted by suntechnik View Post
It depends ...
AD8620
OPA1612
OPA2827
Hi, if your interested. I currently have 2x AD8620AR for sale,
thanks
ian
Old 13th April 2012, 12:13 PM   #16
diyAudio Member RIP
A TL072 is exactly the same size as the NE5532P - standard DIP package.
I've never come across an op-amp that isn't standard size or smaller.
You are mistaken, the parts are the same size.
rgds, sreten.
Click the image to open in full size.Click the image to open in full size.
Old 2nd April 2014, 04:42 PM   #17
TommyD is offline TommyD  United States
Mr. Jabba, Unless you have no other choice, buy your devices from Mouser or Digikey or places like that. Some unsavory sorts of people will straighten the legs of an SOIC device and photograph it in such a way that it looks like a DIP device without any size reference. This may be what happened to you. These devices are industry standard and use industry standard package die on which to mount the actual chips. All 8 pin DIP packages are approximately 340mils X 300mils. If your device is about 200mils X 150mils it is likely a SOIC with straightened legs. They run about a $1.00USD each.
Old 7th November 2016, 03:31 PM   #18
mtoc is offline mtoc
Banned
Is it possible to replace the NE5532 with OPA1612 in my preamp?
Old 7th November 2016, 03:35 PM   #19
DPH is offline DPH  United States
^ Maybe; but do pay attention to PSU decoupling as the latter chip is a LOT faster and needs an adapter (assuming your ne5532 is DIP). It also has a bit of a wiggle in the top of its loop-gain function, which *might* cause instability in some tone-control circuits.
Happy DIYing, Daniel
(This space is occupied by the artist formerly known as Derfnofred)
Old 16th November 2016, 02:52 PM   #20
EmRR is offline EmRR  United States
TLE2072 is the direct upgrade part, sounds better to me.
TL072 opamp replacementHide this!Advertise here!
carver av 505 opamp upgrade for TL072? Htguy Analogue Source 5 5th December 2012 07:39 PM
OPAmp replacement jpy1974 Chip Amps 5 12th March 2007 01:14 PM
TL072 replacement Smiffy Digital Source 1 26th October 2003 09:39 AM
Opamp Replacement Help tone Digital Source 1 19th August 2002 04:41 PM
5532 opamp replacement 2Bak Parts 7 5th May 2002 03:43 AM
Copyright ©1999-2017 diyAudio
