| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I've been looking at regular eletromechanical relays, and they seem to be real good, but they get to be reletively expensive once you get a couple dozen going, plus they take some time and power. Then looking though the Mouser catalog I notice all these Analog IC switches that take hardly any power and have switch times in the nanosecond times. Can these be used just like regular relays, as in feed them 5V or whatever and they switch?
These things look like the great alternative, but didn't know if there were any drawbacks. Also this would be for low voltage levels, like switching inputs on a pre-amp or something, so they don't need to be built like a tank. Thanks, David |
#2 |
Electrons are yellow and more is better!
There are a few very good analog switches out there. The drawbacks are small or few, distortion and noise. In a normal high level (0.1-1 V) application analog switches are good, today.
The cheapest I can think of is 4066 CMOS but Analog Devices (amoung others) has good types. Some types have smooth, silent and click-free switching.
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
If you want high quality analogue switches, you can use SSM2402 or SSM2404 from Analog Devices
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#4 | |
Jan Didden |
#5 | |
one solution which is low noise, low crosstalk, low distortion are opamps with disable function. i would just point out, however, that I have found you have to assert the DISABLE to HIGH in order to enable the opamp (the manufacturer states that it can float.) |
#6 |
It depends where they are. If they are in series with let's say 10 k to an inverting amp, they will perform not bad anyway but you can hardly call them very audiophilic.
#7 |
The CMOS 4066 are used in the old QUAD 34 and 44 preamps
#8 |
maxim has extensive selection and literature on analog sw
max40xx types are way better than 74C/HC or 4000 series for low distortion with sw moving with audio line level voltage i would look at +/-15 V supply parts, on resistance and parasitic C are modulated by voltage swing, both are reduced by high supply voltage http://www.maxim-ic.com/ |
| stepped attenuator w/ analog switches ML 32 reference | jbraas | Analog Line Level | 0 | 19th December 2006 05:00 PM |
| Switches | chipco3434 | Parts | 1 | 16th November 2005 07:56 PM |
| Switches | LizardDefence | Everything Else | 5 | 1st June 2005 09:52 PM |
| A simple way to create dual(or more!) rotary switches out of single rotary switches | stappvargen | Pass Labs | 14 | 17th April 2004 12:33 AM |
| have you ever considered thinking about maybe using analog switches? | travis | Everything Else | 4 | 8th May 2003 08:28 AM |
| Page generated in 0.10464 seconds (77.38% PHP - 22.62% MySQL) with 10 queries |
