Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th March 2012, 01:55 AM   #1
Default AnTek Transformers: Two separate secondary windings?
Hello,
Does anyone know if AnTek transformers can be used with each secondary winding being used separately. A lot of manufacturers I see say that they either have to be in series or parallel...
I do not see any mention of this on the AnTek datasheets. Do you reckon I could use each secondary winding individually?
I do NOT want to use it as a center tap transformer.
Thanks.
Old 16th March 2012, 02:02 AM   #2
nigelwright7557's Avatar
Yes you can.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software.
Old 16th March 2012, 02:06 AM   #3
Thank you Nigel.
Old 16th March 2012, 02:52 AM   #4
zigzagflux's Avatar
Normally, that recommendation is to ensure the user does not attempt to pull full VA out of 1/2 the primary or 1/2 the secondary windings. The core can handle it, but the individual winding likely cannot (or at least will have much poorer regulation than using both). So to be on the safe side, only load each winding to 1/2 of the total VA. You can use both secondary windings individually, but each winding runs at 1/2VA.
Old 17th March 2012, 04:20 AM   #5
Thanks. So for example...
Antek - AN-1212
This would be 12v-1 @ 2.1A and 12v-2 @ 2.1A?
Old 17th March 2012, 04:50 AM   #6
zigzagflux's Avatar
No, that's a 100 VA unit, so you can pull 12V-4A out of each winding simultaneously. 12*4=48 VA on each, which is 1/2 the total VA rating of the transformer. The caution is not to try and pull 8A out of one secondary winding, which the copper may not be rated for.
I see in the data sheet they specifically say the copper is oversized, so you probably do have some overload flexibility, but just be aware of the principle.
Old 17th March 2012, 02:00 PM   #7
Oh I see. Sorry for my ignorance. Well that's good. These transformers are quite cheap actually...
Thanks.
Turning a 6.3 V secondary into a 5 V secondary on an Antek 2T350 tomchr Tubes / Valves 30 15th October 2012 01:20 AM
Torodial transformer - help with secondary windings pvh1987 Power Supplies 2 2nd October 2011 06:45 PM
Shorted secondary windings of transformer Edvard Tubes / Valves 5 29th December 2010 10:22 PM
adding and using secondary windings jrenkin Power Supplies 0 19th April 2010 03:05 AM
Parallel secondary windings jlm Pass Labs 6 27th March 2004 10:39 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
