Newb - need help identifying caps Newb - need help identifying caps - diyAudio
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th March 2012, 09:09 PM   #1
rave0035 is offline rave0035  United States
Default Newb - need help identifying caps
Hope I put this in the right area.
After months of procrastination, I have finally started my "winter" project: recapping my grandpa's 60's Zenith tube stereo (MLT-15). I found the schematics on Sam's and the tuner diagram is awesome, but the amp diagram is a little different than mine (the amp on the schemo is on the same chassis, but has an extra tube and the guts are different).
Long story short, I can't go by the diagrams to figure out the values of all the caps in the amp, and I'm basically brand new to DIY electronics. I have about 5 caps that I'm having a hard time with - they all have colored bands to indicate values. I found this, but I'm still second guessing what I'm coming up with.
Any words of wisdom on figuring these out? I can post pictures if it would help, but I would like to figure out how to read these rather than just having you guys tell me what they all are.
Thanks a bunch. I know I'll be around here a lot over the next few months as I figure this out.
Old 11th March 2012, 10:32 PM   #2
dchisholm is offline dchisholm  United States
dchisholm's Avatar
Yeah, I'm familiar with some of those "winter projects" that get started about the time the smelt runs start.
Going by memory, I think those are paper-and-foil, or perhaps early plastic film, capacitors. If that recollection is correct, I'd be inclined to measure leakage and dissipation before I assumed they required replacement. (On the other hand, a modern film capacitor might provide some improvement over the equipment's original performance.)
There may have been more than one system for color-coding the values. A copy of the ARRL "Radio Amateur's Handbook" from the 50's or 60's may have the information you need to read the code. (Ask at your library - it may be on microfilm or computer file). Yes, a good photo may help but correctly identifying colors that may have faded over time is another matter.
I've probably told you more than I know but I hope it helps.
Dale
Old 12th March 2012, 11:02 AM   #3
Thanks for the help. It seems everywhere on the 'net that I look, people say to rip all the old non-ceramic caps out of these things and replace them as long as I have the chassis pulled. I will definitely be replacing the the electrolytic caps, but it would save me a lot of headache if I didn't have to swap all the others, too. I will post photos this evening.
Old 13th March 2012, 01:42 AM   #4
Here's a closeup of one of the caps - let me know if you have any thoughts.
Old 13th March 2012, 03:39 AM   #5
dchisholm's Avatar
Using the diagram you posted previously, I see 0.033 uF (33,000 pF), +/-10%, 200 V.
A polyester film capacitor rated for 0.033 uF, at 250 V (or higher) should cost roughly $0.50, and be easily obtained.
Dale
Old 13th March 2012, 05:35 AM   #6
nazaroo is offline nazaroo  Canada
Banned
that object with the color bands is a resistor.
The disk cap to the right should have specs or a part # right on it.
Old 13th March 2012, 11:51 AM   #7
godfrey is offline godfrey  South Africa
I doubt it's a resistor. That color code would make it 333 Gigohm.
Old 13th March 2012, 11:15 PM   #8
Dale
Thanks for the help Dale, I just wanted confirmation that I was reading these correctly. On a related note, it's acceptable to exceed the V rating of the initial cap if I can't match the original?
Old 13th March 2012, 11:17 PM   #9
The resistors in this unit look similar, but are brown (rather than black).
Old 13th March 2012, 11:20 PM   #10
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Why not buy an LCR meter ?
Much better than guessing.
Take one out at a time, measure it then replace it with a new one.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Newb - need help identifying capsHide this!Advertise here!
Help identifying caps in Pioneer SA-5300...Thanks unpredictable Solid State 6 7th June 2010 07:39 AM
newb question - replacement caps chopchip Parts 9 21st February 2010 11:40 AM
Identifying SMD chip caps (Newbie here) Safe_Cracker Parts 7 4th January 2006 11:49 AM
Identifying caps, PIO? adalin Parts 3 27th October 2004 04:03 PM
Help Identifying Caps/Res ? Lusso5 Parts 2 23rd September 2003 07:42 PM
Copyright ©1999-2017 diyAudio
