Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Quick question about op-amps
Old 27th September 2003, 10:02 AM   #1
Hybrid fourdoor is offline Hybrid fourdoor  United States
Hybrid fourdoor's Avatar
Default Quick question about op-amps
Im messing around with Circuit Maker and when I place op-amps I can just rename an op-amp right? I mean as long as they have the same kind of inputs they theoretically should operate the same. Like a 8 pin op-amp is the same as another 8 pin op-amp. The differences are gonna be how well in real life they actually perform as an ideal op-amp. Like when it says UA741, I can easily just rename it NE5532 (with the assumption its only representing one side of a NE5532), and it should still come out the same right?
Thanks,
David
Old 27th September 2003, 04:12 PM   #2
purplepeople is offline purplepeople  Canada
purplepeople's Avatar
Default Any CM pros out there?
If we forget that you are using EDA software for a minute and can probably get the actual SPICE model for the specific opamp somewhere...
It's my understanding that since the 741 was introduced, opamps have been such excellent and consistent devices that the signals they produce are almost entirely controlled by the resistors that surround them. We design a circuit with the "ideal" opamp then choose the IC to match the input and output signals we need.
The 5532 is a dual and will have the added problem of channel separation but it is a good device. Maybe CM has a generic dual opamp you can use... it may help with the PCB layout. If you can get the spice model, it might give very slightly different simulations vs. the "ideal" opamp. I haven't used CM in a long time, so I can't be quite sure. Any CM pros out there?
:)ensen.
Those who claim to be making history are often the same ones repeating it.
Old 27th September 2003, 04:21 PM   #3
sam9 is offline sam9  United States
sam9's Avatar
I don't know about Circuit Maker but my experience with other SPICE engines suggests that:
A- If the subcircuit associated with the the symbol is a generic opamp, just changing the label on it "probably" does not alter the simulation.
B- However, that is only "probably". If the the software has a subcircuit available and associated with the lable, then by changing the lable you may be invoking the other subcircuit.
The core thing you should check in the documentation is how does Circuit Maker associate what you see as symbols on the screen to specific subcircuits. Different software does this in different ways ranging from simple and easy to serious mystery and aggravation.
Old 29th September 2003, 07:13 AM   #4
ppl is offline ppl  United States
ppl's Avatar
Every time i have done this it has not allowed a valid simulation getting some error part not found. Had to reinstall this program one so as to get an accurate lab. so ya download a spice model and hope CM reconises the file. Another porblem i have had is with Or cad hijacking all other circuit and pcb files evean when i perset what defaults i wanted. Additionaly or cad captures unrelated files as its own so you can evean open it with the proper program after you assign it to open with..... Always open this type of ile with...... Still to no avail......
Quick question about op-ampsHide this!Advertise here!
2 quick questions about PG Ti amps valterdaw Car Audio 6 15th July 2007 02:51 AM
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 04:20 PM
Quick Question Staticjeep Car Audio 15 8th December 2006 08:13 PM
Quick X-over question DerekB1 Multi-Way 1 17th January 2005 07:29 PM
Copyright ©1999-2017 diyAudio
