Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
3.5 megohm 1% resistor source?
Old 27th February 2012, 01:27 AM   #1
cmbrow@wm.edu is offline cmbrow@wm.edu  United States
Default 3.5 megohm 1% resistor source?
Hi, Folks,
Can any one point me in the direction of couple of these. I've got to rebuild the AC/DC probe of a Simpson 311-2 voltmeter, and these are what I find. I've looked in the usual place, Digikey, Mouser, a couple of surplus places, but can't find anything in this value (tho' I may not know how to search correctly).
All suggestions welcome and closely attended to.
Chandos
Old 27th February 2012, 01:53 AM   #2
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
hi cmbrow, the problem is going to be that 3.5 is not a standard E series resistance value. probably the closest you can get is a 3.48 Meg E192 series (0.1%)
This should be ok as the 1% tolerance of a 3.5 meg resistor would allow it to be in the range 3.465 to 3.535 meg. whereas the tolerance range for a 0.1% 3.48 meg resistor will be in the range 3.477 to 3.483 ohms (you could also use a 3.52 meg also available in the e192 series).
However I've just done a quick search and can't find any 0.1% 3.48Meg resistors (1% yes).
another option may be to use a 1.3M in series with a 2.2M resistor these are available at digikey in 1% tolerance, though I guess that when adding two together you may end up outside the 1% tolerance range. I guess the question is, how critical is the value of these resistors? would a 3.48 1% be "close enough"?
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 27th February 2012, 04:12 AM   #3
Default Thanks!!!!!!
I've placed some 3.48 mOhm Vishays on my Digikey order. The 1% spec is fine for my application.
I much appreciate your quick reply!
Chandos
Old 27th February 2012, 09:20 AM   #4
RJM1 is offline RJM1  United States
3.5 MEG, 1 WATT, 1% RESISTOR
http://www.ralphselectronics.com/Pro...ource=googleps
3.5 megohm 1% resistor source?Hide this!Advertise here!
Source for Resistor sets? athos56 Parts 8 13th November 2009 09:19 AM
source resistor svemir Pass Labs 5 6th February 2007 01:22 PM
Resistor source? jaymanaa Parts 2 24th June 2006 03:13 PM
Why source resistor?i understand it Mordor Solid State 27 27th June 2004 11:47 PM
Copyright ©1999-2017 diyAudio
