| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm trying to identify whether resistors on a board I'm trying to recreate from a photo are either metal or carbon film. They are light brown, like most carbon films I have and have the same shape as a metal film. For example, in the attached photo. Could the bottom resistor be a metal film, or is it carbon? The photo I'm working off of is not clear enough to tell what the tolerance band might be. I am assuming that since they are 1/4w at most, the tolerance band would be 1% if metal and 5% if carbon. Would that assumption be correct?
#2 |
I have found that answer to be yes, by some manufacturers but count the color bands, the number of which provides a good hint toward which type of resistor you have. A carbon film resistor normally sports four color bands. Five and six color bands almost exclusively indicate a metal film resistor.
| Metal Film or Carbon Film Resistors in Marcof PPA-1h ?? | Ron AKA | Solid State | 15 | 17th September 2011 05:28 PM |
| Resistors, metal film or metal oxide? | gil1 | Solid State | 2 | 14th November 2010 02:16 PM |
| Looking for 0.6 watt metal film resistors | Bushulo | Parts | 5 | 8th June 2008 07:06 PM |
| Carbon film vs metal film resistors in a stepped attenuator? | G | Tubes / Valves | 17 | 22nd August 2004 12:22 AM |
| Metal film resistors or carbon film in a tube amp? | G | Tubes / Valves | 220 | 31st March 2003 01:57 PM |
