Help Identifying Caps/Res ? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd September 2003, 01:43 PM   #1
Lusso5 is offline Lusso5  United States
Lusso5's Avatar
Default Help Identifying Caps/Res ?
I've got some tweeters with built in x-overs, and I would like some help determining the x-over-point.
The two components I can visualy see on the back of the mount are:
a white rectangular piece with markings "3R9-J 5W-KM-8 Mu" (Capacitor ?)
a blue cylinder with markings "V/C BENNIC LAR BI-POLAR IFD 10MFD NV 50WV" there are no colored bands on this piece; it is all blue.
Would someone help me identify what kind of parts they are, in-turn, what mods they are making to the driver?
Thanks in advance.
Old 23rd September 2003, 02:47 PM   #2
Apex Jr is offline Apex Jr  United States
Default Parts
The white rectangle part is a sandstone resistor
3.9 ohm at 5 Watt 5% (J)
Bennic is the Manufacturer of the cap which is a
10 uf at 50 working volts.
Steve @ Apex Jr
Old 23rd September 2003, 07:42 PM   #3
Lusso5's Avatar
Thanks Steve. Im starting to get the picture now, but does that cap identify the ohm rating?
The tweeter casing has 4ohm on it, but a 4ohm 10uf cap would cross it over at 4000hz (from the chart I have).
The tweeter is paired with a 8" woofer, and I just dont see why they would cross it over at 4000hz. I have the factory parameters on the woofer, and response is flat till 2000hz, but then it breaks up.
Could this cap be a 8ohm 10uf ? That would cross it over at 2000hz (makes more sense), but what does that do to the output/impedence?
Help Identifying Cap..... dmongrain Parts 13 1st June 2009 03:20 AM
Identifying a cap... EchoWars Parts 4 27th August 2006 10:43 PM
Identifying SMD chip caps (Newbie here) Safe_Cracker Parts 7 4th January 2006 11:49 AM
Identifying caps, PIO? adalin Parts 3 27th October 2004 04:03 PM
Help with identifying some caps and their values on a phono preamp uniuniunium Parts 62 9th November 2003 04:52 PM
Copyright ©1999-2017 diyAudio
