Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Understanding Capacitor specs
Old 11th February 2012, 10:56 PM   #11
jcx is offline jcx  United States
5000 hr 125 C rated cap life is much better than 10,000 hr 105 C rated cap life, if both are ran at 50-60 C you might expect even in a "hot" chassis
Google electrolytic temperature life derating
given better processing, materials today you should also be able to up the V rating in the same case size - also contributes to longer life, but not as strongly as temperature derating
if any Electros can be identified as being "in the signal path" then looking for non-polar construction with high V rating could be an improvement according to Bateman's meaurements
Old 11th February 2012, 11:02 PM   #12
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
Thank you! that helps make the decision easier. Once i get the amp apart I will take a good look at what and where each cap is in the circuit. I doubt Krell would put EL's in the signal path. I Do see plenty of film type caps in there as well.
Zc
It's not about what you can BUY...It's about what you can BUILD!
Old 13th February 2012, 06:44 PM   #13
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Is ripple current rating an issue for a 200uF cap? (as it sounds like a small value electrolytic, as opposed to a large electrolytic PS cap)
Understanding Capacitor specsHide this!Advertise here!
HELP! Capacitor specs for Sonic Frontiers SFC-1 Control Amplifier devilsindetails Tubes / Valves 16 17th April 2012 01:03 AM
Need help understanding class B output stage capacitor variations dunndatt Headphone Systems 1 1st October 2010 05:21 PM
Help Understanding Old meter specs Zero Cool Equipment & Tools 2 21st June 2008 12:01 AM
non-understanding oversampling Bernhard Digital Source 26 3rd March 2007 09:32 PM
Amp understanding / help bear-hifi Solid State 2 7th February 2006 03:26 PM
