Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 30th January 2012, 02:35 PM   #1
Default ??repairable??
Anyone else ever come across this problem? Is it possible to resolder the tab on or should i try and get another one? I have 5 other ones and was hoping to salvage this one for another project.
Old 30th January 2012, 02:50 PM   #2
GloBug is offline GloBug  Canada
Banned
When it comes to lytics it's nice to know you have a fresh intact part.
Heat would be a concern but give it a try. I don't know if the "snap-ins" are more sensitive or not to heat.
Clean the parts well first to minimize soldering time. Acid flux would do it, but would have to be completely cleaned afterwards.
Old 30th January 2012, 03:19 PM   #3
do you think it would be a bad idea to clean it completely and solder on a 8/32 nut to use it with a cut down machine screw?
Old 30th January 2012, 03:29 PM   #4
KatieandDad's Avatar
It depends on what the connector pole is made from ?
You might be able to drill and tap the pole piece.
I'd replace it personally. If it's aesthitically important then gut it and use the body as a cover for the replacement part.
Old 30th January 2012, 03:33 PM   #5
Not that important just was trying to save it is all..... they were given to me so i don"t know who makes it
Apogee Ribbon Repairable? Help! Bernie7 Planars & Exotics 5 30th July 2011 02:42 AM
speaker repairable? kanifee Multi-Way 4 2nd July 2008 07:30 PM
Repairable or Rebuildable? Help a noob. tjh Full Range 12 3rd March 2005 10:23 PM
Repairable? eXn Subwoofers 10 18th February 2005 09:39 AM
Is this burned board repairable phishead8 Solid State 9 27th July 2004 06:52 AM
Page generated in 0.08038 seconds (71.13% PHP - 28.87% MySQL) with 11 queries
