Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Op-amp requirements for a I/V converter?
Old 26th January 2012, 05:41 PM   #1
Audio Maniac is offline Audio Maniac  Brazil
Default Op-amp requirements for a I/V converter?
Imput noise density, slew rate, gain bandwith, THD + N, settling time or open-loop gain, which of this parameters really matters when choosing op-amps for an I/V converter of a DAC?
Old 26th January 2012, 06:28 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
All of them, and depend on how much you want to spend, but all things together is expensive.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 26th January 2012, 06:42 PM   #3
jcx is online now jcx  United States
Originally Posted by jcx View Post
if you put a C acrosss the feedback R giving a single pole low pass then there is little need for excessive slew rate - can be part of the anti-image/reconstruction filter
ideally higher frequency error V at the op amp input would then be reduced by ~ fc/GBW
with the feedback C there is a "feedthrough zero" that gives a small input Vdiff glitch at current steps due to the op amp output Z - decades old I/V app notes described the advantages of a low impedance output buffer inside the loop for op amp I/V
the op amp slew rate spec can still be a proxy for input diff pair linear operating range with degeneration, fet inputs improving both
but the low Vnoise parts can't have much degen
a compleltely new "highly linear" diff pair is used in AD8099/ADA4898 family parts - I think the ADA4898 is the best combination of specs for audio DAC I/V available today
you would need to look with a very good 'scope to see if ccs bias of the output to either rail helps - the ADA4898 has a 50 mA "linear current range" spec so you could bias at several times the fs current of most audio DAC chips
Old 26th January 2012, 10:23 PM   #4
Let me place the question in a different way. Among the listed parameters, which are the most relevant?
I need to choose a pair of dual op-amps for I/V convertion but they must be electrically compatible with NE5532. I searched about this subject but all recommendations where based mostly on subjective tastes. I would like to get a technical explanation about the matter.
Old 26th January 2012, 10:35 PM   #5
wahab is offline wahab  Algeria
http://www.ti.com/lit/ds/symlink/pcm1794.pdf
Old 26th January 2012, 11:05 PM   #6
The PCM1794's datasheet informs gain bandwith, settling time and slew rate affects the audio dynamic performance of I/V section.
So imput noise is less important for this application?
Old 26th January 2012, 11:18 PM   #7
Default why trade off when you can get "very good" or "best" in all categories at once
you might want to read the Hawksford paper I refence in the 1st post: http://www.diyaudio.com/forums/digit...ml#post2218591
I show a sim of glitch at the input of the I/V op amp - Hawksford shows that you should want to minimize a function like the V^2 time integrated error V
GBW is the biggest help, low output Z as I mentioned makes the feedback C work better
the function to be integrated also depends on the linearity of the input stage - the ADA4898 uses a new linearized BJT input stage that is unmatched by previous monolithic op amp tech
if I've done the calc form the patent correctly the input stage gm is linear to -120 dB with |4 mV| input differential - the same number for a low noise bjt op amp is ~100 uV
so the ADA4898 has high GBW >50 MHz, high "linear output current" spec f = 100 kHz, SFDR = −70 dBc, RL = 150 Ω 40 mA, >50 V/uS slew rate, low 1 nV/rtHz noise - all together - and avaiable in duals
I/V S/N is limited by DAC I_fs and the larger of op amp Vnoise/Rfdbk or op amp Inoise - so op amp Vnoise can be reduced in importance by increasing R, increasing output V swing
Old 26th January 2012, 11:35 PM   #8
SoNic_real_one is offline SoNic_real_one  United States
I just got today some THS4032 (TI). Noise: 1.6nV/sqrt Hz; Slew Rate: 100V/us; Settling Time: 60ns, THD: -90dB at 1MHz; BW: 100MHz!
Another contender that I have at hand is ADA4897-2 (AD). Noise: 1.0nV/sqrt Hz; Slew Rate: 85V/us; Settling Time: 96ns, THD: -115dB at 100kHz, -93dB at 1MHz; BW: 230MHz!
I am planning to use them as I/V stage after a PCM61P - it has a settling time of 350ns. I am planning to get rid of the SR limiting capacitors in the I/V stage.
I just need to wait to get the adaptors from SMD to DIL.
Old 26th January 2012, 11:44 PM   #9
the ada4897 is new to me - the Vnoise looks very good but the chip has a max |Vsupply| of only 10 V so +/-5 V supply would be its limit
pkg is msop - 20 mil pin spacing is challengening to hand solder - but the size is probably required to keep lead/layout inductance low - I am suprised they didn't use a better pinout
I really wouldn't try to use a 230 MHz op amp on an adapter
Old 26th January 2012, 11:47 PM   #10
The ADA4897-2 is also new to me. I'm amazed with its great specs, but unfortunately its power supply operating range is 3 to 10V. I need an op-amp which supports 15V.
Op-amp requirements for a I/V converter?Hide this!Advertise here!
op-amp + op-amp buffer combinations eccdbb Chip Amps 2 22nd July 2011 05:13 AM
Power transformer for tube amp requirements Joshua_G Tubes / Valves 14 11th July 2010 03:04 PM
Op Amps for Balanced Line Converter dkingham Car Audio 12 2nd August 2006 01:33 PM
Power requirements for 7 channel gainclone amp? AJ Bertelson Chip Amps 18 23rd May 2004 12:16 AM
8" Subwoofer amperage requirements theholmboy Subwoofers 2 26th February 2004 02:15 AM
