I have bought a transformer kit to wind a 4v-4v output. The primaries come pre wound, here is the layout starting at the top most tag with the primary side of the transformer on my right hand side and the secondry (no windings yet) on my left hand side,
--------------- 0v (a)
--------------- 120v (b)
--------------- 0v (c)
---------------- 120v (d)
how do I connect this for 230v operation?
Raja
Raja
For UK operation:
Hi Raj,
Connect B to C.
Connect 230v (240v) between A and D. (Best to connect live to A, and neutral to D).
Although the UK is quoted as being 230v, the allowable voltage tolerance is asymetrical, and the actual average mains voltage is 240v. So I wouldn't worry about the 10v difference.
Hi Raj,
Connect B to C.
I've just tried connecting b to c, and supplying ac to points a and d. However the transformer is humming very loudly and begins to heat up rather quickly......
So i disconnect from mains.
Is this happening cause I've not yet wound secondries????
Or am I getting something wrong?
Raja
Raja
Your hunch is correct I haven't connected the laminations
In any case, the formula for calculating the secondries is number of volts required X 4.16.
the kit is 100va
Add 1% per 10va.
I need 4v at 1.1 amps.
I am using .9mm enammelled copper wire which gives around 2 amps.
So 4.16 X 4 = 16.64 turns
plus the extra for the va around 17 turns.
So i need to make 2 seperate windings of 17 turns each?
The supply is for a tube rectifier heater.
Once I have made the 2 turns how can I measure with my DMM to see if this is correct?
I assume I set it to 200vac and attach 1 probe to each of the secondries?
Given that the transfo won't be under load, should I expect a higher voltage reading????
Raja
the kit is 100va
Add 1% per 10va.
Raja
Hi Raja,
Glad that fixed it And that the transformer will be put to a good use
With regard to winding, this is what I'd do:
Use some thin hookup wire and wind a temporary secondary, as per calculations. Connect to one valve and adjust turns if necessary. Remove.
Now wind the secondaries properly. There should be no "fudge factor required for the extra load of a second valve, because the transformer is 100VA.
If the rectifier valves are directly heated, the windings will be at HT (+B) voltage. Ensure sufficient insulation.
Edit: When connecting to the valve, use approximately the same length and gauge of wire you intend to build with. Also, use a valve socket if you have one. Measure the voltage on the actual valve pins.
Finished the heater supply for the 3a5's and it works fine (2.87v at output), a tiny bit higher than the suggd 2.8, but perhaps it will drop just abit on load?
This is the first time I've built without a pcb and I'm quite pleased with my layout, unfortunatley don't have a camera for pictures!
I've just wound the secondries and attached the laminations.
Have put a jumper wire between points b & c, also wired ac hot to a and cold to d.
When I switch on there is still quite a bit of a buzz.
Can I use my Dmm to measure the secondries directly without connecting to the az1 tube, just to make sure it works?
As there is no centre tap, do I just set to 200v ac and apply one probe to each secondry?
Raja
Raja
Hi Dhaen,
I measured the output of the secondry, whihc is 3.5 v, a little short....
I'll have to redo using an extra turn or so.....
The annoying thing is the level of buzz I'm getting from this, it really is excessive,
my secondry winding wasn't overly neat, but this is buzz is really loud..
any ideas???
raja
any ideas???
raja
Raja,
I don't understand what this 200v thing is all about. Are we just talking about heaters, or something else as well. A schematic, even hand drawn in M$ Paint would help.
About the buzz: Make sure the laminations are bolted or clamped together tightly, and that you've fitted all of them. If using bolts, check whether they should be using insulated washers. The secondary should also be tight. When you're sure of it, add some laquer to hold the windings completely still.
hi,
Here's the schematic for the output stage,
http://www.ultranalog.com/cdenhancer/cdenhancer2_3a5.pdf
Raja
Raja
thanks for posting the schematic
Raja,
So the 200v is the HT secondary? OK.
For the purpose of testing the heaters, do not connect this.
Are you saying the heater windings have no centre-tap: No problem, just use R8 & R9 as per schematic.
If you are saying that the 200v winding has no centre tap, you could be in trouble
BTW, what signal transformers are you using?
Raja,
HI,
The HT secondry is actually 115v, and is centre tapped........
The 4v-4v supply for the rectifier on the HT supply is not centre tapped........
The output transfo's are the sowter 8650...
Will let you know how I get on.
Out of interest could the heater on the AZ1 rectifier not be fed with regulated dc instead of ac?
Thanks for all your help and patience
Raja
Raja
Hi Raj,
Good.The HT secondry is actually 115v, and is centre tapped........
No problem.The 4v-4v supply for the rectifier on the HT supply is not centre tapped........
Hmm, I'll have to look that one up.The output transfo's are the sowter 8650...
Yes please.Will let you know how I get on.
Absolutely no point and no. Because they're directly heated it would really complicate things.Out of interest could the heater on the AZ1 rectifier not be fed with regulated dc instead of ac?
You are welcomeThanks for all your help and patience
- Design & Build
- Parts
- help connecting primaries
