| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Does anyone know where to get just the round machined pins used in 2.54MM headers, or something similar? I need way too many to sit and break the plastic off by hand, but not enough for some min. 30,000 piece order from China.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#2 |
Try digi-key under "Connectors, Interconnects" -> "Terminals - PC Pin Receptacles, Sockets" .
You will not like the price, you can probably buy an 8 pin socket for as much as a single loose pin. But they are nice, you can use a bigger than normal hold and insert the pins right into the PCB, creating essentially a socket flush to the board. Last edited by macboy; 20th January 2012 at 06:31 PM. |
#3 |
Thanks, but I wasn't specific enough. I meant male header pins.
Looked through the "PC Pins" section and didn't see anything with the proper dimmensions. Like you said though, the price is a little bit much for a single pin.
#4 |
#5 | |
Looks like they might have one that will fit my needs, and they offer samples. EDIT: This one is perfect, if I can figure out how to press them in the PCB straight and without breaking them..... http://www.mill-max.com/pin_rec_cata...-15-00-00-03-0
"If you don't like funerals don't kick sand in Ninja's face." - Ninja Last edited by theAnonymous1; 20th January 2012 at 09:03 PM. |
#6 |
Interesting data on those pins.
61.5% copper content and conductance drops to 26% ref copper. 3.1% lead content and they claim ROHS compliant. Did they mean to say that the free machining requirement allows them to apply for an exemption?
regards Andrew T. |
#7 |
So far I just ignore ROHS mostly due to the fact that I'm soldering with 63/37 Kester. What is the threshold on lead to be considered ROHS compliant?
#8 | |
RoHS = Restriction of Helpful Substances
Anyway.... Quote:
#9 |
Received my samples from Mill-Max today, they are absolutely perfect for my needs! I found a distributor that has them for only 4.7 CENTS each! Everyone else sells them for 50 cents each.
I built a jig out of a small c-clamp so I can press the pins in evenly without breaking them. Now I can make pro quality SOIC to DIP adapters for less than $1. Suck on that, BrownDog. ![]() Going to place an order for 2k pins on Monday.
#10 |
Banned
That's sweet.
| Why spacer strips and not dots? | Penguin87 | Planars & Exotics | 5 | 7th October 2010 08:50 PM |
| Which spacer thickness to use with ESL? | chinsettawong | Planars & Exotics | 39 | 27th January 2009 12:17 PM |
| What is the preferred metal for spacer | d3imlay | Solid State | 3 | 14th March 2008 03:40 AM |
| Which Plastic | Mats J | Multi-Way | 4 | 27th January 2005 12:46 PM |
| plastic | give me a name | Multi-Way | 4 | 5th June 2003 04:11 AM |
| Page generated in 0.10220 seconds (79.69% PHP - 20.31% MySQL) with 11 queries |
