Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th January 2012, 05:12 PM   #1
lanchile's Avatar
Default wima polyester or polypropylene cap?
Hi. I would like to use a 4.7uf 50v wima cap in the input circuit of an amp. but My question is if there is a difference in quality or sound of these two kind of polyester/polypropylene caps. I only have 5mm approximate for the connections of terminals. or should I just get bigger/better caps and use wires to connect them on boards? I have never use them,How are these Wima caps?
Old 14th January 2012, 05:44 PM   #2
SY's Avatar
Wima makes excellent capacitors. The polypropylene would be a better choice in that position.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 14th January 2012, 05:56 PM   #3
lanchile's Avatar
Thanks SY, now the problem is if I get the polypropylene they are bigger than 5mm. Mouser does not have in the 5mm, they only have the polyester in 5mm. I found some Wima 5mm polypropylene in ebay but I am not so sure if they sell original ones. I have to keep searching for a store that sell original Wima.
Old 14th January 2012, 07:16 PM   #4
MKP2s only go up to 0.33 uF:
WIMA
I use MKS2 (polyester) capacitors for the input high pass in power amps.
MKPs tend to get bulky and makes it difficult to keep the input network compact (which IMHO is important to minimize noise pickup in a power amp).
Old 14th January 2012, 07:33 PM   #5
lanchile's Avatar
WIMA
That MKS2 is the one I wanted to use from Mouser. But I am not sure if I should get a better one like Kimber,Auricap,Sonic cap etc and just solder the wires to the 5mm space terminal in the amp board.
Old 14th January 2012, 07:39 PM   #6
SY's Avatar
In what way are those caps "better"? Other than profit margin?
Old 14th January 2012, 07:55 PM   #7
lanchile's Avatar
Good point! I just assumed that the other costs more money because of the material,winding methods,tolerance etc that make them be "better". I think there must be a bad,good and better caps right? like in everething else in this world.
PS: I just need some "good" and "reliable" 4.7uf NP 50v caps. to replace some Panasonic Fc in the input signal that are installed right now.
Old 14th January 2012, 08:04 PM   #8
SY's Avatar
Mostly, it's a matter of market segment. The best caps are those made with very tight winding, solid potting, and reliable leadouts. That means "major manufacturer."
Old 14th January 2012, 08:11 PM   #9
PMA is offline PMA  Europe
PMA's Avatar
Here you will find WIMA polyprops 4.7uF
WIMA
They "sound" definitely better than the polyester types.
Pavel Macura, consultant
http://cz.linkedin.com/pub/pavel-macura/4/783/637
Old 14th January 2012, 08:24 PM   #10
lanchile's Avatar
As you can see in pictures ,I do not have to much space on board to use big caps. Cap #1 is the one I have to use the 4.7uf at least 50v. the Wima polypropylene are wider than 5mm from terminal wires. that is why I was thinking of using the others caps put it as close as I can and just solder terminals.
Polypropylene Mega Cap?? MilesOttawa Multi-Way 29 17th March 2011 09:44 PM
When to use Polyester / Polypropylene or Mica / Monolithic Caps? LosNir Parts 7 23rd March 2010 06:32 PM
Rifa & Wima polypropylene capacitors xecluded Swap Meet 8 1st September 2008 12:46 AM
Is this SMD Metallized Polyester Film Cap any good? Brian Guralnick Parts 10 10th October 2003 08:57 PM
dayton polypropylene cap, polarity? zx3chris Parts 5 31st March 2003 03:16 AM
Page generated in 0.10715 seconds (77.53% PHP - 22.47% MySQL) with 11 queries
