Looking for transformers to build +5V, +12V power supply for CD-ROM drive - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th September 2003, 10:43 PM   #1
Default Looking for transformers to build +5V, +12V power supply for CD-ROM drive
I'd like to build a linear power supply for my CD-ROM drive. I looked at Avel-Lindberg, but didn't find any transformers with different output voltage secondaries. One option is to buy separate transformers for the two supplies (say 15V and 8V secondaries or something). I guess another option would be to build a 12V supply and use a voltage divider to get the 5V? But then a sag in one supply would make the other one sag too... but a voltage regulator will probably take care of that?
Has anyone done this before? Are there any transformers out there that I can use for this? Anything else I need to know or watch out for?
Thanks,
Saurav
Old 18th September 2003, 10:58 PM   #2
I done this before, used an 50VA 12Vac transformer.
LM7812 for the +12V dc / 1.5A
MAX724 (Switching regulator) for the +5V dc / 5A
Works very nice.
Old 18th September 2003, 11:01 PM   #3
I know what the LM7812 does (I have LT1085 so I'd use those), I'm not familiar with the MAX724. So it's a 'switching regulator'... takes in the 12V, and produces 5V using PWM? Doesn't this defeat the purpose of building a linear power supply though, if I use a switching regulator?
Old 19th September 2003, 10:43 AM   #4
I used the MAX724 to limit the dissipation loss in de regulator.
12Vac => 15V dc under load. The CDRom player I have uses about 1.5A on the 5V line, with a linear regulator this would be a loss of 1.5A x 10V = 15W. in the regulator. With the MAX724 I reduced the loss to 4W. You can add an output filter to make the dc more smooth, see the datasheet for examples.
You can find the MAX724 datasheet here:
http://www.maxim-ic.com/quick_view2.cfm?qv_pk=1269
Old 19th September 2003, 03:21 PM   #5
Thanks, that makes more sense. I was thinking about the heatsink requirements for the 5V regulator, and wondering if I should drop some of the voltage in a power resistor and the rest in the regulator.
Thanks for the help.
Variable DC power supply to drive TT motor IZHAKKATZ Analogue Source 9 9th April 2009 09:33 PM
Toroidal power supply transformers crippledchicken Parts 6 21st June 2006 09:46 PM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 10:52 AM
PC Power Supply transformers pokka Car Audio 3 3rd August 2004 08:25 AM
Build a Power supply For amp. Dj BASS AMP Car Audio 3 24th May 2004 05:23 AM
Copyright 1999-2017 diyAudio
