Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
need help identifying components
Old 13th January 2012, 12:57 AM   #1
bzhei is offline bzhei
Default need help identifying components
hi,
i need help in identifying these components. some of them are found in the feedback loop of the op-amp in parallel with the resistor. i figured they might be capacitors. if they are, i can't seem to find any info about them
here are the photos.
is it possible to make out the values of whatever these components are by looking at the labels?
they are marked 2A 220, JDC 102, SE 103.
and would also like to know what this is. there is a LT1072 beside it and an electrolytic cap before going into a zener-transfomer track
thanks.
Old 13th January 2012, 01:03 AM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Yellow blobs are capacitors.
Biege component with 3 orange bands is a 33k resistor.
LT1072 is a switch mode regulator.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 13th January 2012, 04:04 AM   #3
thanks nigel,
how do i know the values of the yellow caps? i tried removing one of them and my meter could only read down to .003nF and it doesn't register the value? could be in the pF range?
also, the last photo, i'm refering to the black component with 201k Y0N2 labeled. could this also be a cap? and what value is it? can't seem to find it on the google.
Old 13th January 2012, 04:55 AM   #4
embrown057 is offline embrown057  United States
103=10nf or .01uf
102=1nf or .001uf
220=220pf
028=29pf
Old 13th January 2012, 05:01 AM   #5
The 201k may be a 200Mh choke.
Old 13th January 2012, 05:11 AM   #6
benb is offline benb  United States
I'd say with 95 percent certainty that that's an inductor. The LT1072 uses an external inductor for its operation. Go to Linear Technology's website for the datasheet, that should give you some idea for the range of the inductance, as well as helping trace the circuitry. The circuit almost certainly uses a "standard" circuit shown in the datasheet.
http://www.linear.com/product/LT1072
Old 13th January 2012, 05:30 AM   #7
madtecchy is offline madtecchy  England
Hi
@ Bzhei .This may be usefull for you
Old 13th January 2012, 05:37 AM   #8
LT1072 - 1.25A High Efficiency Switching Regulator - Linear Technology
thanks. i'll go run through the lt's data sheet again.
Old 13th January 2012, 05:38 AM   #9
Originally Posted by madtecchy View Post
Hi
spot on madtecchy! just what i needed. just printed it. thanks a lot!
Old 13th January 2012, 05:50 AM   #10
by the way,
what is the composition of the yellow caps?
can i replace them with Wima metallized polyprops? they're used in my old equipment that i want to freshen up. and there are just a few of them in the board.
need help identifying componentsHide this!Advertise here!
Identifying 2 smd components sorenjepsen Parts 3 24th January 2012 11:30 PM
Identifying scrap components KatieandDad Parts 2 14th January 2012 11:38 AM
Identifying smd components pedefede Parts 2 5th January 2012 11:38 PM
Help identifying components gerb0027 Tubes / Valves 15 16th December 2010 10:40 PM
Field Guide to Identifying Components ? vonfilm Parts 6 20th October 2008 04:52 AM
