Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
need help identifying components
Old 13th January 2012, 08:29 AM   #11
madtecchy is offline madtecchy  England
They look to me like axial ceramic multi layer composition. depending what they are doing in the circuit changing to metalised polyprops may do more harm than good.
Regards Ian
Old 13th January 2012, 08:40 AM   #12
davidsrsb is offline davidsrsb  Malaysia
220 = 22pF and would have been a reasonable NP0 or COG dielectric.
102= 1nF and 103 =10nF would have been X7R and not much good if the value actually matters.
I am not sure what the "028" is
The ferrite part is a 200uH shielded inductor, it looks like a good quality part
Old 13th January 2012, 10:39 AM   #13
DF96 is offline DF96  England
Originally Posted by embrown057
The 201k may be a 200Mh choke.
200mH (or 200uH).
Old 13th January 2012, 12:06 PM   #14
Enzo is offline Enzo  United States
You read the numbers on the caps in picofarads as if you were reading a color code on a resistor. So 221 would be like red-red-brown, and would mean 220pf. 103 would mean the same as brown-black-orange, so 1-0-000pf, same as 0.01uf or 10nf.
Old 13th January 2012, 12:17 PM   #15
bzhei is offline bzhei
Regards Ian
i checked the circuit, the 220 caps are paralleled with a 33kohm resistor and used between the op-amps + input to RCA ground lead. the 103 caps are also paralleled with a 33kohm resistor but this time in a feedback loop from op amp output to inverting input. a 104 is used between +12 supply to gnd of the equipment itself.
Old 13th January 2012, 12:27 PM   #16
i just removed the cap with 028 marking. it actually read SE 103 on the other side. the 028 must have been a manufacturer code. thanks
Old 14th January 2012, 10:07 AM   #17
The inductor is 220uH, not 220mH. A 220mH ferrite choke would be enormous.
Actually values of the order of 100uH are typical for these low power switching power supply chips
Old 14th January 2012, 01:24 PM   #18
embrown057 is offline embrown057  United States
Thank you David for the correction, your correct.
need help identifying componentsHide this!Advertise here!
Identifying 2 smd components sorenjepsen Parts 3 24th January 2012 11:30 PM
Identifying scrap components KatieandDad Parts 2 14th January 2012 11:38 AM
Identifying smd components pedefede Parts 2 5th January 2012 11:38 PM
Help identifying components gerb0027 Tubes / Valves 15 16th December 2010 10:40 PM
Field Guide to Identifying Components ? vonfilm Parts 6 20th October 2008 04:52 AM
Copyright ©1999-2017 diyAudio
