Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th September 2003, 06:32 PM   #1
Raj1 is offline Raj1  United Kingdom
Default what to look for - diodes
I'm looking for good diodes to use as rectifiers, upto 8a.
I've seen people reccomending schottkys, hexfreds and mur8**,
So what's good?
Say for digital circuits, tube heaters etc.
I have found two different types which I have read are good
http://www.farnell.com/datasheets/11398.pdf
and also
http://www.farnell.com/datasheets/13000.pdf
but also at farnell I have found cheaper diodes which have faster recovery times - as low as 15ns.
what's the view?
Raja
Old 18th September 2003, 01:44 AM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Hi Raj,
For tube heaters I use Schottky's. Apart from being quiet, they also have very low forward voltage drop, which is an advantage as there is less voltage loss, and much less heat generated.
Farnell do some TO220 insulated tab types. I forget the number. These are easier to mount.
diodes changsecho Solid State 1 31st May 2008 04:32 PM
Old Diodes betweenpie Tubes / Valves 2 3rd June 2007 04:06 PM
Ss Diodes?? resident Tubes / Valves 37 28th October 2004 08:38 PM
Diodes carlmart Chip Amps 0 4th March 2004 11:50 AM
Page generated in 0.07686 seconds (71.18% PHP - 28.82% MySQL) with 10 queries
