Maybe this is something teached to EE, but since I'm not one (or not yet), I don't know things like this.
I'm asking this question to the people who design theyr own circuits.
When I see a schematic, I'm always wondering how have the parts been choosed. When I try to do it myself, and look for a BJT on manufacturer's websites, I see hundreads of transistors in dozens of categories, and I'm incapable of choosing with the small knowledge I have.
Is there a consencus about classical transistors to use, or at least to start with? I'd like to know it
Alex
Alex
First you must know three things:
Current, voltage and power
Then:
current gain and fT (speed)
Then:
capacitances, linearity (if those data are available)
Last: Can I buy them easily? Second source?
Since you are in Europe, BC8xx and BC5xx for small signal are classical
BD139, 140 for drivers
Many more types to choose from when it comes to output transistors.
Note this are examples only!
Then:
Then:
Current gain for small signal transistors is usually not a problem but sometime it's nicer to have 400-600 current gain instead of 100-300. This will become clearer if you start to calculate every single stage in an amp.
fT is a little bit harder to determine what you need at least. Normally driver and output transistors are most important and also hardest to find speedy parts.
It's often good but in those cases some other parameters gets worse....
If you have chosen a 100 MHz and the bandwidth gets too poor you may have to change the transistor but sometimes you can change the design and get a faster amp.
You see, it's many considerations. You must know what you are after, then you can start the hunt.
- Design & Build
- Parts
- How do you select the transistors (or mosfets, rectifier diodes, etc) to use?
