MR 67 Coupling Caps - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd January 2012, 02:59 PM   #1
drjb is offline drjb  Canada
Default MR 67 Coupling Caps
Hi, I'm trying to figure out which caps (I assume output coupling caps) most influence the sound of my MR 67. A schematic is available here:
http://vintageshifi.com/mcintoschmr67.pdf
Am I right to think that C53/C54 and C56/C57 will influence the quality of the sound, the most?
I thought I'd like to upgrade these caps to PIO or VCaps, depending on size and cost.
Any and all info much appreciated!
thanks,
John
Old 3rd January 2012, 03:35 PM   #2
DF96 is offline DF96  England
The LF point is set at the input to the audio circuit (as it should be) by C79/80 together with the 1M resistors. This means that the electrolytics in the audio output stage will not have much signal voltage across them, so cannot generate much distortion. There may be some advantage in a small increase in the value of C54/57 to, say, 22uF as this will avoid an LF rise. Apart from that I would leave it as it is. Sound quality of an FM tuner is set mainly by RF and stereo decoder circuitry, not the tiny bit of audio stuff at the end.
Old 3rd January 2012, 03:42 PM   #3
DF96, sounds like this is a plan I should abandon. I changed the old, tired, stock output tubes, which transformed the sound; was hoping for the same with the output caps.
thanks
Old 3rd January 2012, 03:56 PM   #4
You could check the caps for value and leakage, as they may have deteriorated. If OK, leave alone. If not, replace.
It's a pity the stereo decoder sits right on the page boundary as it makes it hard to follow the circuit!
Old 3rd January 2012, 04:27 PM   #5
Overall, it's in great condition, no issues with it, at all (now that I've replaced the output tubes and one other).
It's not the best manual, but at least it's available.
Old 3rd January 2012, 08:20 PM   #6
Jebem is offline Jebem  Portugal
Jebem's Avatar
Nice Tuner from Mcintosh.
As I see it, old equipment tends to have more than one component with altered values, like capacitors and resistors.
So, it takes a lot of effort and work to put the equipment back in good shape.
For the resistors, use a good multimeter and check them, and replace all the ones having a drift bigger than 15%, in particular for the high values in the 100Kohm and above region.
For the electrolytic capacitors, I would replace all of them, not just the two 1uF output caps that You mention.
There is a reason for this: these type of caps have a limited life, especially when operating in warm environments like tube systems. Most likely, old electrolytic caps will shows leaks or even worse, they just dry and loose capacitance.
At least consider replacing the power supply caps and all power supply bypass caps with new electrolytic ones of good quality.
For the output capacitors, just use new good quality electrolytic caps, or if You fancy expensive better caps, use MKP type as a minimum - try WIMA caps, they are good and not really expensive ones.
As DF96 states, it is not worth to use VCaps on this design.
And let us not forget a basic rule, if we remove one old resistor or capacitor from the circuit, the best procedure is to replace it with a new one. Just in case.
Old 3rd January 2012, 09:48 PM   #7
Thank you, Jebem!
Value of coupling caps john dozier Tubes / Valves 14 11th February 2011 06:49 PM
For sale: ClarityCap MR coupling capacitors wimdehaan Swap Meet 1 13th June 2009 11:18 AM
Coupling caps. Trebla Class D 5 1st March 2006 09:12 PM
coupling caps??? AudioGeek Parts 14 16th September 2004 12:05 PM
What value for the coupling caps? roibm Parts 12 23rd March 2004 05:58 PM
Copyright 1999-2017 diyAudio
