Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd January 2012, 01:18 AM   #1
Default UTC LH-519/FH-757 xfmr info?
Hi:
I have a pair of UTC transformers marked FH-757 and North Atlantic 202348.
I found an expired auction on eBay for UTC LH-519 transformers that also displayed North Atlantic 202348 so I know they're equivalent.
They are marked 10k ct: 5k ct, 50 cps - 20 kc, 0.13W
I'm curious if these might be usable as tube/valve interstage transformers, and if so, what kind of DC current would be reasonable.
I found a schematic for the North Atlantic Instrument they were used in and they were used in a (solid-state) phase angle voltmeter, so I cannot infer what kind of DC current they might tolerate, or make too many analogies to tube circuits.
P=E^2/R for 10k and 130 mW = 36 v...not too encouraging, but I don't know what the power rating context was.
Thanks for your thoughts.
Murray
Murray
Old 4th January 2012, 10:18 PM   #2
I found a Philco Radio history site that had a post recommending capacitor coupling to a IS primary to eliminate the DC. for longer life (probably referring to already-ancient radios).
That's another option...if they can handle much voltage...
Murray
Old 11th February 2012, 05:51 PM   #3
I think these are not intended for tube/valve voltage levels...so they must wait for another opportunity to surface...
Murray
Pioneer A-757 cseko Solid State 0 2nd March 2011 01:04 AM
el509/519 horn150 Swap Meet 2 20th September 2007 08:48 PM
Peavey FH-2 FH2 FH1 FH-1 Folded Horn info X-Ray plans please! Peavey MB1 MB-2 Multi-Way 0 6th February 2006 03:50 PM
need some info in a UTC s-16? anyone! Rockmonton Tubes / Valves 1 13th November 2004 07:28 AM
El/pl 519 Megaboss Tubes / Valves 3 21st September 2004 08:40 PM
Page generated in 0.06847 seconds (70.30% PHP - 29.70% MySQL) with 10 queries
