Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Can I look for (or even measure) distorsion on an amp with a dual scope?
Old 16th September 2003, 03:21 PM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default Can I look for (or even measure) distorsion on an amp with a dual scope?
Is this possible?
Old 16th September 2003, 03:32 PM   #2
On Hiatus
SY's Avatar
Yes. If your scope has an A-B setting, you can measure large amounts of distortion. It takes an attenuator and a fiddly hand to null out.
For a better measurement, use a precision instrumentation amp with high CMRR at the frequncies of interest to compare input to (scaled-down) output. Then you only need a single channel.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 16th September 2003, 04:06 PM   #3
Bricolo's Avatar
If by A-B, you mean a dual timebase, yes it has one.
It also has little calibration pots for the vertical sensibility
I was trying to play with the CH2 invert, in ADD mode, and adjunsting the sensibilities to cancel the signal, and see if sometimes there is a difference
but it's not easy to adjust the signals to cancel them
Is there a better method? And only with a dual scope, no other lab tools
Old 16th September 2003, 04:20 PM   #4
stokessd is offline stokessd  United States
stokessd's Avatar
In Nelson Pass' article on the Citation 12 (in his archive section I believe), he describes how to use the amp to "measure itself" which is a slick system. I haven't tried it and havent thought too hard about it (it's a bit of a self licking ice cream cone) but it's something to check out.
Sheldon
Old 16th September 2003, 04:43 PM   #5
On Hiatus
SY's Avatar
No, I meant a setting that would subtract B from A, while letting the voltage scale be different on the two channels. A + B with an invert is just as good. Try scaling down the output externally, with a voltage divider and a 10-turn pot for trim; that will make the null a little less twitchy. But only a little less.
Old 16th September 2003, 04:53 PM   #6
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Sy,
I gather you propose to oput the input signal on one channel, to put an attenuated version of the output on the other, then subtract and null for min level.
This will indeed let you large amounts of THD only. But the phase shift through the amp will also limit the minimum you can get, unless you also delay the input signal and equivalent amount. It gets messy quickly.
I know that this method has once be proposed by Linsley Hood it was (or maybe Peter baxandall), but he used a series circuit of two adjustable phase shifters for the input network. He then subtracted the scaled down output of one channel of his amp (because the amp was inverting, he just connected the two channels together IIRC). The result (ideally, the THD only) was fed into the other channel, allowing him to listen to the distortion. Slick, but not for the faint of heart.
Jan Didden
Old 16th September 2003, 05:00 PM   #7
On Hiatus
SY's Avatar
Is the delay really an issue at midband?
Old 16th September 2003, 05:03 PM   #8
jan.didden's Avatar
Hmm, good point. I don't know really. I do remember the involved phase shifters in the Hood/Baxandall example.
What would be a typical delay through a power amp? A microsecond? That would be only a fraction of a degree at 1kHz. Yes, I think you're right. Seems worth a try.
Jan Didden
Old 16th September 2003, 09:06 PM   #9
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Bricolo
I noticed that you insist on using a scope but honestly it's not really suited for distortion measurements. You'll get much better results if you use a decent soundcard, possibly with a buffer pre and some spectrum-analyser soft
Old 16th September 2003, 09:37 PM   #10
Guido Tent is offline Guido Tent  Netherlands
Originally posted by analog_sa
Bricolo
I prefer a distortion analyser with residual output, and I like time and frequency domain both, can't live without each of them
I am in a luxuary position, own an HP339, an HP3580A and daily access to an AP one.....
regards
Guido Tent
www.Tentlabs.com
Can I look for (or even measure) distorsion on an amp with a dual scope?Hide this!Advertise here!
Can I use a scope to measure powerline noise? Saurav Equipment & Tools 31 5th January 2017 04:32 AM
How to measure JLH Class A with a Scope chris ma Everything Else 84 28th December 2012 08:13 PM
Test Equipment (TTi Dual Current-limiting PSU, LFM4 Generator, Hameg 'Scope) thermionic Swap Meet 3 18th September 2008 04:10 AM
Good way to measure transient distorsion ?? youyoung21147 Multi-Way 30 31st March 2007 07:12 PM
Want to measure V on the scope: should I buy a new one or build a low noise preamp? Bricolo Parts 43 1st November 2005 08:41 AM
