Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
24DB 4th order ~75HZ Component Question
Old 29th December 2011, 08:44 AM   #1
mfrobel is offline mfrobel
Default 24DB 4th order ~75HZ Component Question
Greetings Fellow Users,
I am new here and I have a pretty basic question that I myself am having a bit of trouble with. I want to build a 4th order 24DB High Pass at ~75HZ for my Eminence Kappa Pro 12" speaker. Could some one please help me calculate the mH for the two inductors, uF for the two capacitors? Is there a calculator that I can use for these calculations? I hope I have posted this in the right forum section. Thank you in advance for any help you may have to offer
Old 29th December 2011, 09:16 AM   #2
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
I find this calculator useful --> Crossover Design Chart and Inductance vs. Frequency Calculator(Low-pass)
Be aware that you will need a very large inductor, and also that a theoretical filter that you get from the calculator won't necessarily be what you really need, as it will depend on what the response curve of the speaker is like, and the impedance curve as well.
at such a low frequency I would suggest you should look at an active crossover and separate amp for the bass driver.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 29th December 2011, 06:11 PM   #3
Default 24 DB Calculater
Very good! That was extremely useful. The box that I intend to build per the manufacturers instruction for the Eminece Kappa Pro 12A, is a large bandpass enclosure with a 24DB filter for the 12". I haven't figured out the rest of the networks yet. According to them, this is the way to get the most bass response without pushing the excursion limits. After all the speaker is really a very large mid bass. I intent to load the box with a 6" mid range, a horn, and a tweeter. The woofer, and mid will have their own manufacturer specified separate enclosures within the cabinet. It will be a fun project. I just thought I would share the fun! Thanks again.
Martin
24DB 4th order ~75HZ Component QuestionHide this!Advertise here!
1st order to 4th order conversion Professor smith Multi-Way 22 28th November 2011 11:41 AM
4th order Digital XO with Time delay - Question Docks Multi-Way 6 28th August 2011 10:01 AM
My 4th order sub hjf Subwoofers 2 17th January 2011 02:40 PM
My 1st order butterworth filter better than 4th order L-R: Why? philipreji Solid State 61 1st March 2007 05:50 PM
Newbie question about 4th order subwoofers red Subwoofers 3 14th September 2003 04:21 PM
Copyright ©1999-2017 diyAudio
