Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Relay
Relay
Old 5th January 2012, 11:36 AM   #11
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Can you provide a link ?
Old 5th January 2012, 12:00 PM   #12
R.I.P.
New TCJ Stepped Attenuator
shows a HQ version.
A3 Stereo Stepped Attenuator
shows a balanced version that replaces the 3 switched unbalanced version.
I can copy my old unbalanced version and the resistor changes to make it work properly and post pics.
regards Andrew T.
Old 5th January 2012, 12:14 PM   #13
I was VERY disappointed with the 23 step attenuator that I bought last year. It was just too coarse.
My idea is to build a 50 step attenuator. OK it will need to be digitally controlled but it will use relays in place of the limited number of switch contacts.
Old 5th January 2012, 05:07 PM   #14
R.I.P.
Originally Posted by AndrewT View Post
It could be implemented with relays rather than rotary switches.
My idea is to build a 50 step attenuator..........it will use relays in place of the limited number of switch contacts.
regards Andrew T.
Old 7th January 2012, 09:22 AM   #15
AndrewT, not sure of the point that you are trying to make in #14.
My idea is to build a simple decade counter which can have many more than 23 possible outputs, I harped at 50 but 40 would probably do. Each output can then switch a relay providing many more than the 23 step (coarse) limit of a rotary switch.
This gets expensive on relays, hence my original post #9.
RelayHide this!Advertise here!
When is inrush relay necessary? eem2am Power Supplies 4 28th December 2011 08:10 AM
Relay hugobors Parts 6 21st February 2006 10:20 AM
Looking for the best relay carlmart Solid State 15 19th August 2005 12:06 AM
Help with relay ppereira Solid State 14 21st June 2003 08:10 AM
Relay or not relay ? Yonnat Pass Labs 10 10th April 2003 07:26 PM
