Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st December 2011, 04:14 PM   #1
PreCD's Avatar
Default M5 Solder Lugs - Of All Things
I have hunting for some 90 degree M5 solder lugs for a filter recapping project I am starting. Digikey did not have them nor can I find them elsewhere.
If you have some it would make a swell Christmas present! Or if you want please share where you got them.
Old 21st December 2011, 08:53 PM   #2
I have absolutely no idea what a M5 solder-lug is. Could you post a pix or drawing? E
Old 22nd December 2011, 12:03 AM   #3
Enzo is offline Enzo  United States
Solder lugs should be common enough. Are you specifically searching for metric? Try looking for just solder lugs without the M5. Solder terminals maybe. Most of the ones I see are in imperial sizes, in other words, they fit a #10 screw. M5 is roughly the size of a #10, isn't it?
And as to right angle, if you mean bent in the middle instead of flat, well, you have pliers.
Keystone makes a variety, the type 905 is referred to below.
http://www.keyelco.com/pdfs/p77.pdf
http://www.mouser.com/catalog/catalogUSD/644/1656.pdf
Mouser sells stock 534-905-10, which fits a #10 stud. WOuld that work?
Old 22nd December 2011, 12:34 AM   #4
GopherT is offline GopherT  United States
Just go to the hardware store and buy some solderless (crimp - type) connectors for the right wire size. Then cut the plastic off, crimp, and add some solder to make it secure and reduce interference. Done in two minutes with no shipping costs.
Old 22nd December 2011, 01:17 AM   #5
PreCD's Avatar
Enzo:
Most helpful information. Just an hour ago I ordered these:
Solder Tags Hot-tinned brass,M5 / 2BA (100 Pack)(CN157) | eBay
And these:
SOLDER LUGS TERMINAL #10 - LOT OF 40 | eBay
I think a #10 will work.
Did not need that many but hey now I have an excuse to start future projects.
GopherT:
Did that for some projects but this one requires a different approach. If I could post a pic of the amp at this time you would see what I mean. I have a ground bar that runs through two of the caps in one continouous string. Can not use your application but thanks for the input. I just did this very thing for my tweeter connections! (Where were you then? )
Old 22nd December 2011, 03:01 AM   #6
Hey, I just signed up to the site to learn about vintage transistors and stumbled on your post. Maybe I can help next time.
Cheers.
GT
Akai M5? mark adams Tubes / Valves 0 4th July 2009 05:55 PM
Pioneer M5 destroyer X Solid State 15 14th May 2009 08:10 AM
Things important to be said..helped by Mr. John Mateus to express things. destroyer X Solid State 22 31st July 2006 07:21 PM
Source for OFHC O-Lugs Greg Stewart Parts 0 21st July 2003 03:36 AM
Page generated in 0.07930 seconds (76.92% PHP - 23.08% MySQL) with 10 queries
